My son has got a 2013 GTI and off late I've noticed a vibration which I can feel through the floor and when in the passenger seat. I can also feel it at low speeds but is much worse at motorway speeds. The car was with the local VW dealer who have simply blamed the tyres and maybe tracking? But I always thought that balancing would show/resonate at certain speeds and then go away below or above that speed? The car was also booked in for loss of turbo power randomly but sods law, it didn't exhibit the problem when they had it and there were no fault codes thrown up either when they connected the car up.
Anybody have any ideas, getting the wheels and tracking checked will be the first thing he'll get done but I'm not convinced.
Check the tyres for odd wear. My original mk5 golf blew the inside of a tyre out at 40mph, the mechanic I pulled into could actually put 3 fingers through the inside of the tyre wall. Spare on and too the tyre shop we went. New tyres all round, £450. Laser tracked and it was 6mm out and looking at the tyres that were removed it was really bad. Couldn't feel anything odd while driving though, no odd vibrations but the mk5 gti is a little rough anyway. Lost the car 2 weeks later in the snow at low speeds, never putting Kumho's on my car again.
Now spending far too much money on 'bits' for it.
) or just powder coat them.
, had 3 of the 4 replaced under warranty due to white worm 2 years in but they are the same again now. Pity there are no steel wheels that will fit over the PP brakes.
