The Elder Scrolls V: Skyrim Remastered - MODS & TWEAKS
Can anyone help me out here.
I'm trying to play Special edition in Ultra wide (3440x1440), but none of the UI fix mods seems to work Inventory, skill tree and focused conversation subtitles all get get off one way or another.
Also I don't think my other mods are working inc some body replacement mods and what not. I'm using Nexus Mod manger as well if that helps.
Hmm I had the same issue and I found a mod that fixed it , when I get back from my office I will take a look and update this post.
Time for my current mod list. Load Order sorted by Mod Organizer, and all mods here are from the Skyrim SE Nexus. If you have any questions about a mod I'll try my best to answer it. Still need more! :D
https://i.imgur.com/BMUrzEw.png
Mod Organizer ? imgur is buckling ATM :(
I had even tried removing the SE version of SEE and SkyUI and I still get the UI issues, not that SkyUI worked as well. I wonder if I have a general mod/nexus mod issue
One sec killboy.
Does this work? https://ibb.co/kfwiN8
What about Mod Organizer are you questioning? It's a mod manager like Nexus Mod Manager but better/more advanced.
It tells you missing master plugins, sorts by the correct load order, can run LOOT, TexGen from inside etc.
One sec killboy.
I might give that a go, I only use maybe 10 mods at most,
which out of that mega list was for 21:9 UI's
Try "Simply Bigger Trees" first, Once without, then once with the mod and see if you see a difference. That is a very noticeable mod.
https://www.nexusmods.com/skyrimspecialedition/mods/5281
Or remove all mods from Nexus Manager, get Mod Organizer: https://www.nexusmods.com/skyrimspecialedition/mods/6194 and set it up for Skyrim SE. Download the mod manually and add via archive (second from left icon at the top of Organizer)
yer it did'nt work
I did then work out what the issue was, NMM picked up the old location of SKSE i installed it to not my current on a new drive, changed that and reinstalled trees and Boom. I just need to reinstall the others and get around the achievements thing
I'm getting a black screen when enbseries loads right at the start, and having to reboot the PC to resolve. Is this a common conflict with something? I've not tried an enb for ages, so not sure if something's changed?
I'll need to start from a fresh install I think. It may be the Ultrawide fix that's causing it... Which mods do you guys use for 3440*1440 resolution?
Also, is SKSE still not available for Special Edition?
No worries :)
I had a lot of issues with SKSE and getting things to work so I left it. I would use SKYUI but not sure how easy it is to setup.
