yeah, that conversion is around £12k lol.The Car Throttle guy (Alex?) is also putting a V6 in "Phil" (his MX-5), I think he's going to do a video series about it.
yes v8 miata lol.
honestly 200-240 would be more than enough, I can't say I struggle with current power, it's fun around country lanes and keeps up with most cars due to how well balanced it is and how well it handles!
So? Get it done man! No balls, calling you out, crying inside going from that straight six sound to a washing machine.
Z4 is much closer to being a washing machine than a well sorted MK1 MX5.![]()
I've yet to see an MX5 keep up with my Washing machine then![]()
Yeah, I always felt mine just needed that bit extra but nothing crazy. I wanted to go the mini charger route but I reckon turbo is the most versatile and cheapest option with room for more if you fancy. Car I'm about to post in the daily encounters is almost at 350 with a built engine, have yet to get a ride in it though but they say it pins you back and keeps going for what it is.
Santa Pod, pick a date![]()
You've probably spent your cryto millions to gain an unfair advantage pushing 1000whp probably![]()
Outside of noise I don't see the appeal in the V6 conversions for the MX5, the Mazda KL makes sod all power for its size, and the while the Jag AJ30 makes decent power you can have a well sorted, reliable 250-260hp turbo conversion for a quarter of the cost
No crypto millions for meso just a paltry 270hp(ish) at the moment
Well you've won there, more power and less weight than the Z4
^^ Gorgeous, Eyedot
(Not sure about the old boxster though)
I thought you'd only just had it detailed Gibbo?
And the M3 as well?
If you need them both detailed already then you need to stop using them for rallying, or find a better detailer.![]()
