Think you'd be better off with the proper mount and use conduit. Conduit is available in black or white.
Something like this?It's not a requirement, but would be safer and more reliable. I have some on my outside wall in black, it doesn't actually look too bad
Ah right, that all just seems so big for 1 ~6mm cable surely?No, not that. See here:https://www.screwfix.com/c/electrical-lighting/plastic-conduit/cat830584
Can anyone help me with this idea? I think I've settled on how i want to do a set up.
Can you assist me in choosing an NVR for 8 cams and a separate PoE box, my idea is this.
Have the cables from the external cams go up the wall the the attic where they plug in to a PoE box, then a single cat5 cable going to the bedroom.
The reason for this is, I have no power in the attic and wanted to have the nvr in the bedroom.
Would an NVR such as the Hikvision 7608 work like this even though it has all the PoE ports?
I did wonder about thisThe PoE box/switch will still need power. In which case you may as well keep the NVR up in the attic too.
With NVR recorders can you login and record from a smart phone? I would be concerned that should the NVR be stolen, all video evidence will be gone as well, defeating the object of having cctv in the first place.
