Don't think any cam with IR will work through glass without getting glare.Wish I researched better before buying.
Standard Arlo doesn't do motion zones, no biggy can angle it more.
Appears it doesn't work well through glass. And CBA drilling through masonry and part of the reason I wanted it inside was to "hide" it, I could try and glass suction holder but then it's games trying to focus it.
Any suggestions? Just want a cam, pointing over the drives watching the cars.
I'm looking at upgrading my 7 year old D1 system.
However I'm stuck with the existing cabling.
Am I best looking at AHD or IP with ballums ( I think that's what they are called )
I currently have 8 cameras and would be looking to initially replace the DVR and 3/4 cameras and then do the rest as and when.
Any advice you knowledgeable folk can offer would be much appreciated.
I went with Hikvision and 2-3mp analogue cams to reuse the old in place BNC cabling. Quality is superb, and cams super cheap on ebay only £40 odd.
Remember security is never convenient for the 'users', but same applies for the installer! It will require a bit of work. I'd really recommend making a hole and putting one outside though. Not that difficult at all and I guess you'll know someone with a drill if you don't have one. Plus if it is visible it acts as more of a deterrent
Hmm that's no good!Mounted outside. Think I need a smarter cam. It picks up on the reflection of my car parked on vehicles passing. I can also walk through it and it will only pick me up almost when I'm done walking through.
So get a lot of motion alerts for nothing and nothing when theres a lot of motion.
Well i've gone and ordered one of each - 2385 can go on the second story covering the whole front of the house and the 2335 will go about 1.5 stories up to cover the drive and main doorWill be interesting to see the difference!
Have you installed these yet? Wondering what cam is the best all-rounder
First 8 port you've linked to, and same as what I bought I believe, says in the description it does H265+How important would you say H.265+ was?
Use-IP only list one 4 port Hikvision NVR, but is doesn't support it. https://www.use-ip.co.uk/hikvision-ds-7604ni-k1-4p.html
They have two 8 port NVRs, the cheaper one is stuck on an old firmware (and I'm sure it also doesn't support it) https://www.use-ip.co.uk/hikvision-ds-7608ni-k2-8p.html, and the other is more expensive at £313.80. https://www.use-ip.co.uk/hikvision-ds-7608ni-i2-8p.html
This is NAS/microserver price. Not sure what to do now. Any thoughts or suggestions?
How is the 2385 at night please?obviously only day time at the moment (as per previous note the 2335 is behind glass till I finish painting & fit it properly).
These are both partial crops of items about 20m away - the 2385 is significantly clearer
I'm hoping to get the 2335 mounted next week cover the car from a different angle so will report back when its done![]()
