Road Cycling
18 Oct 2002
England
In the space of 40 miles yesterday the Arione wrecked my backside, plus I think my prostate is going to explode. No cut-out and the wings have rubbed the insides of my thighs.
16 Feb 2004
London
I've got a pile of saddles to sell after trying loads out. In the end found the pro stealth carbon the best compromise of man bits not falling off, comfort and getting in a good tuck position. Can't stand saddles with no cut-out now.
25 Nov 2009
Are 11spd SRAM and Shimano chains interchaingeable?
Time for a new one for my bike using SRAM groupset but found a brand new ultegra chain in my box of bits.
On the topic of saddles.
I ride a PN 3.0 now and whilst I wouldn't call it comfortable I will stick with it. It's the least bad of all the saddles I've tried. Far more comfortable when full aero as opposed to up on the goods.
24 Oct 2002
Bucks and Edinburgh
Hmmm, not convinced on this!
What’s there to be convinced about? Being lighter means you go up hill faster and being heavier means you go down hill faster, it’s gravity at work. The difference with respect to a set of wheels in reality is virtually nil as we are normally talking about 200 to 300g which makes little to no difference and is the difference between have a crap or not before your bike ride, all things being equal as mentioned before.
18 Oct 2002
Notts
Rate of acceleration under gravity is independent of mass (Galileo). Technically this is in a vacuum, true. Air resistance and rolling resistance are then the factors, and we're assuming the same profile of wheel, which is fine. More mass/weight will mean greater rolling resistance though.
Aero should be where people focus on though, I agree. Air resistance increases with square of speed, and power requirements to sustain a certain speed scale with the cube of speed. Rolling resistance scales linearly with speed.
18 Oct 2002
Notts
Frontal area of a road bike is pretty small. Aero bikes can make meaningful savings though, if you're serious. The wacky UCI-outlawed shapes and creations will always be most effective, so very large surface area to volume ratios of frame tubing.
25 Mar 2008
Zip 404s are hardly much lighter at 1615g and cost nearly £1600!
Also, a few 100g is neither here nor there once you have 2 full water bottles and you're sat on the saddle (not calling you fat btw).:D
I suspect the light deep section is probably the AX lightness ultra 55t http://ax-lightness.de/en/cycling/bike-components/laufraeder-rennrad-ultra/ultra-55t/ at well over £2000 and 1125 grams. That's a lot of something else for your 575 grams
Aero over weight every time.
I would rather have aero wheels weighing 1700g than those £5k lightweight climbing wheels.
Ditto.
People end up in turmoil over this not really realising that tyre choice, position on the bike and even the spares you're carrying or water bottles chosen are more likely to have significant impact than 1-200g.
Unless you're competing in Hill Climbs, factor it it but don't let it be the deciding factor.
Thanks for the help. Could I get more guidance/suggestions?
My bike is a Planet X London Road - a £1k aluminium framed commuter bike with Sram Rival and hydraulic discs (I can sense the roady sick rising in the back of your mouths!) with £100 cx wheels. It's got clearance for wide tyres and isn't very aero.
Here's a pic.
Please forgive the set-up It's left over from when I co-opted it into triathlon duties... The saddle is a bit higher and forward than usual.
I was considering upgrading the wheels to improve performance.
I am currently working on weight loss, but I do other sport besides cycling. I'm probably approx 19%ish bodyfat, give or take 3%, and about 93kgs at 187cms. I've come down from 110kgs. Realistically I'm going to struggle to lose more than a few kgs - I'm aiming for 88kgs but this will take a while.
In the meantime, I'd like as much help up hills as possible (on a budget of £300-400)
24 Jul 2003
floating down the Liffey
The performance improvement gained from wheels is often overstated. This looks like a nice set within your budget that may save a few g's over your current set but don't expect to knock minutes off your hill times. That comes from training!
https://www.huntbikewheels.com/coll...-light-disc-road-wheelset-1449g-28deep-22wide
The upper weight limit is 100kg so you should be fine.
Liam how badly broken is the Antares?
It has a crack in the shell near the middle. It might actually be acting as a sort of suspension when it flexes, improving comfort.:D
27 Feb 2003
Shropshire
If you want some carbon wheel loveliness, Wiggle/CRC have their own brand Prime wheels reduced
http://www.chainreactioncycles.com/prime-rr-38-carbon-clincher-disc-road-wheelset/rp-prod142958 - £410 for 38mm
http://www.chainreactioncycles.com/prime-rr-50-carbon-clincher-disc-road-wheelset/rp-prod142960 - £439 for 50mm
27 Feb 2003
Shropshire
Can you recycle old bike components anywhere? I was tidying up in the mancave last night and found the original 11-25 cassette & chain from my Planet-X. **** knows how I got up any hills on that sucker, so it's unlikely to go back on. Seems a waste just to lob it in the rubbish bin though...
Also got a random collection of stems and seatposts.
18 Oct 2002
Fife, Scotland
Using the same wheelset along with Schwalbe Pro Ones, I was using clincher tyres with no complaints for a while.
Decent upgrade from the stock Giant wheels for me.
If I'm to be picky I'd say the freewheel is loud in comparison to the Giants, which is silent. I quite like it though lol
18 Oct 2002
Fife, Scotland
Thanks @Shamrock and @#Chri5# Forgot to mention, I have a masisve preference for silent freewheels. My current wheels are pretty loud - I hate people hearing when I'm easing off!
Yea that's why I thought I'd mention it, its not for everyone but having said that the freewheel is definitely not the loudest I've heard...
On the plus side it's good for making people aware you're there. :)
1 Oct 2008
Designing Buildings
Popped out again last night .The wind put me off going on a longer ride so did the same as monday. Knocked a minute off my time but could have been quicker as I hit traffic on the quicker section and there isn't much room in the country roads to meet anything :o
