Man of Honour
- 21 Nov 2004
I really dont know ive never hurt my neck before - maybe was my head position? I also tried having bar lower on my back recently....
How strong are your traps? Do you do deadlifts?
Which part of your neck? Back or front, or side?
Wearing lifters isn't about performance, it's about enabling a better bottom position if you high bar squat to depth. Only a tiny amount of people can achieve a good deep squat in flat shoes, since it's not a natural position for your body to be in (having a heavy bar on your back whilst still keeping a vertical torso is not the same thing as hanging out at the bottom of a '3rd world squat' where there's no spinal loading). If you're only squatting to parallel and/or low bar squatting, it tends to come down to proportions, and there are now more options for hard-soled shoes for lifting other than the Olympic ones with the large heel lift (Metcons, Nanos etc).
I do deadlifts currently at 130kg
I was doing 95kg squats for 5 sessions and decided to move up to 97.5kg - it felt okay a bit hard....
(also did shrugs on the Wednesday which may have not helped?)
back of neck and movement painful is putting neck forward and a little if I turn it right
Got my Belt today,
Wow,
Just wow.
That felt so solid, Should have got one ages ago haha
https://www.amazon.co.uk/dp/B004XJOX2U/ref=pe_3187911_185740111_TE_itemNice. Got a link to the belt you went for?
well I did shrugs and deadlifts on Wednesday and I must admit it did feel a bit tight thur/fri but not painful
I then did squats and it was definitely not on my neck - I had it much lower than normal - so could it have been my neck position when squat has aggravated what I did on Wednesday?
And people wonder why I say shrugs are dumb?
Take a few days off and then get back in with some proper exercises.
its starting to ease off and starting getting my full range of movement back.... do you think it will be worth having a week off? (ive been training 9 weeks without a break)
I was just doing some shrugs as assistance exercise - what do you recommend for the traps
Power cleans and snatch grip deadlifts.
And then deadlifts.
I probably kill myself doing power cleansim not so flexible so that prob rules out snatch grip deadlift - I do deadlifts - but cant really see that hitting traps much?
what about snatch grip high pull (from hang/blocks) and snatch grip rack pull (from ~2" below knee) then?
Both less technical and require less flex![]()
Less technical? *chuckles*
But high pulls are the greatest trap exercise going if you do them "right."
Shrugs are fine if done right. I always do them at the end of a deadlift session.
