Where did you order the FireBoard from, my next purchase and angusandoink seems the place I will go unless you found a better deal!?
Just went with bbqeurope.com
Nevermind....misread the post.
And I will probably ask again next!
Ahem
Sorry man. I saw my name tagged in your post but didn't realise that you were actually asking @oneilldo![]()
@thewanted , ribs still cookin?![]()
Oh damn, BBQ too hot? What internal temp did they get to?
Can't fault that charcoal though. It's ridiculously light compared to the imported stuff but seemed to last very well.That's this one?
https://www.johnlewis.com/weber-master-touch-gourmet-system-grate-charcoal-bbq/p721702
Seems significantly smaller cooking area - are the Webers worth the premium?
Struggling to find detailed pictures of it - what's the central separate looking grill about?
At a friend's bbq this weekend we did some 'smoked' pulled pork. Smoked for 3-4 hours and then finished in the oven for another 3-4ish hours to get it cooked through.
However one piece ended up perfect to be pulled and the other two didn't, and were nice but not pullable and soft like the other piece.
They were moved around while smoking to try and get it even, the only difference might have been the shelf in the oven or that the good piece was on a dish on its own and the other two were together.
Other than that could it just come down to what the condition of the cut was in? All were around 1.25kg of pork shoulder with the skin and some of the fat trimmed.
Get some of these to help get lit. Put one in the base of your chimney hand one in the middle of your coals, and you'll be fired up in no timeJust ordered the Weber Master Touch for £209
https://www.bbqworld.co.uk/m/weber-barbecues/charcoal/weber-mastertouch-57cm-black-charcoal-bbq.asp
Can't wait to get stuck in. Was tempted with a gas because I've limited time when I get home from work in the eves and with a toddler who needs to go to bed. But been told with the chimney starter it shouldn't take that much longer. Fingers crossed.
