Caporegime
- 9 Nov 2009
- Planet Earth
AFAIK AMD is dual sourcing at both TSMC and GF for 7NM Ryzen.
I hear you, Lisa Su is already making really public statements about it and production though so I am pretty confident it is not a complete flop.Nailing 7nm is absolutely crucial for AMD - they can't be making allowances for foundries not delivering they need to hit the ground running with whoever has the best node :s
You mean complete flop as the Intel's 10nm?!
Well, no, 7nm is OK, up and running, and successful.
It has never been any talk about it being a flop![]()
I also hope AMD improves performance/watt too so all the people on YT/forums who think you need £150 boards to run a £150 Ryzen,can stop worrying!!![]()
Some people need to get informed that Ryzen's efficiency and power consumption is better than anything Intel has to offer. That's why we will see in no time 32-core Threadrippers with very decent 200ish W TDP.
And Ryzen 2's IPC is already equal to Skylake's.
Just because something is lower end in it's VRM design does not mean it will not function at stock or even for some time at overclocking.
What it does mean is that it will run hotter and have a higher chance of failure if you decide to push it, especially as a hardcore enthusiast to the bleeding last 50Mhz edge.
We cannot have an AMD that is competitive on price, but also performance and power consumption? no no no that just wont do the hardware gospels dictate Intel must be king.
All hail Intel All hail Intel All hail Intel
In some areas AMD CPUs have their weaknesses but overall they offer a far better deal than their intel counterparts.
Almost forgot Mesh on the latest intel 7XXX CPUs is really bad compared to the older 6XXX series CPUs like the 6950X which don't use it.
It is almost as if intel had to half bodge the 7XXX series CPUs to get them out the door because AMD are giving them serious competition.
The reason why mesh performs "poorly" is because just like with Ryzen,a number of games are based on oldish engines optimised for ring bus CPUs using a certain cache arrangement. So unless a dev optimises the games for newer gen CPUs,you will see a performance drop. OTH,if you look at Intel mesh and what AMD did with Ryzen,for increasing core counts sucessfully it works much better than the Intel ring bus apparently,except too many game engines are way behind the times.
The thing is the traditional Ring Bus like what coffeelake still uses eventually breaks down once you have too many cores running on it, this is why both Intel and AMD come up with new systems, Intel's Interconnect Mesh and AMD's Infinity Fabric.
Intel's Mesh still relies on Monolithic dies while AMD's IF can break the die up into Chaplets, what that means is AMD get much higher yields out of the wafer and they can build single packages with more cores than Intel, in fact Intel are on 28 Cores with AMD currently on 32, the 32 core is about to become their HEDT CPU while the server CPU's get 64 cores and 128 Threads, Intel can only dream of that.
Now add to that with this higher intercore latency design necessary for very high core counts AMD still achived an IPC equal to that on the Ring Bused Coffeelake while Intel's mesh is trailing badly as you will see in the chart below.
The only area actually where AMD still fall behind Intel is with outright clock speeds, but that on 7nm will change in a few months on Ryzen 3000, on top of that Ryzen 3000 is rumoured to get another 15% IPC bump putting its IPC way beyond even Intel's Coffeelake.
Note that Skylake-X here is running at 4.6Ghz vs 4.2Ghz on the 2600.
It is bad news though when a 7980XE @4.8 performs worse than a 6950X @4.4 in gaming software.
The real question here is what have intel been doing all these years while they dominated the market, what did they spend their R & D on if AMD can produce something better with a fraction of the resources?
