Installed properly the waterblock today.
While benching the temps does not exceed 45C even heavily overclocked at 50% fan speed the Predator 360. Same applies to HBM ram sitting 45C max also.
My only temp that cannot get is the hotspot sensor. It escalates to 106C, however the is nothing around the card that is warm. Neither the backplate. Some help welcome
FYI on Air the temps were hitting 70C for GPU and 80s for HBM.
Side effects. Because of low temps the card is hitting power limits before temps. It tries to push the GPU to 1800 where before at same settings was operating at 1727. Consequently it hits power limit somewhere and stops.
My low voltage settings went out of the window also. At previous 900mv the power consumption now is 100W higher, as is the speed.
I will drop all way down to 800mv later this week and experiment.
Using the default "power save" mode, the performance is higher than before (~15%) as same power envelop (176W).
As i will continue experimenting will update.
