Just ordered the white one, it'll be here later today, can't waitJust ordered the black one looking forward to building it.
How are you finding your new case?
Great case if I'm honest, I like the way the motherboard sits forward enough so i can hide the wires. Fan cooled atm but will look into water cooling as i have seen some fantastic looking builds which are water cooled. will you be water cooling or air cooling?
the black case blends in nice with my black table also, so almost looks like it was build into the case. will post some pictures when i get home from work. my only small, tiny issue was not having a DVD drive bay. but i brought a usb dvd drive so problem solved.
did you go with the -
My basket at Overclockers UK:
- 2 x Lian-Li O11D-1 PCI-Express Riser Cable - Black= £54.95
was meaning to ask if this has any benefit at all cooling wise or is it just cosmetic. will looking into getting this tho as i don't like the way the card sags at the back, looks like it needs to be propped up the riser would sort that issue.
with all the glass on the case and everything inside it does get heavy. But great case was fun building it also
DEMCIflex 360 filter case had 2 filters i took the one at the top off not sure if they are the same ones.
didnt like the AIR version at all.
I set mine as air coming up from the bottom 3 fans where it is cooler and 3 on the side coming in, Put the rad at the top to act like an exhaust
loving the case, going to look into water cooling.
do the DEMCIflex filters use magnet power to stay in place or it is a glue/sticky (ie... filter once fitted cannot be removed)
The pics of the filters on OcUK make it look like it is sticky.
No, you can use this fine with air cooling on the GPU. Just make sure to populate the bottom with fans, and the side mounts too
Is the best place for an AIO radiator in the top or the side? I’ve got an H105 in the side at the moment but with only 2 out of 4 fans connected (don’t have enough fan splitters at the moment for my usual push-pull setup)
Aesthetically, I prefer it at the side but would be willing to put it up top if the performance was worth it.
