I think the freesync version is DP 1.4 (144hz) and the Gsync version is DP 1.2 (120hz OC) due to the Gsync module?
Nvidia should really release a DP 1.4 Gsync module and phase out the DP 1.2 version, it is now out of date and actually making Gsync worse than freesync.
I know they already have the HDR1000 DP 1.4 module, but they should also have a normal DP 1.4 and phase out the DP 1.2.
i know i'm starting to sound like a broken record but what nvidia "should" do is to just dump that stupid proprietary module and go with the adaptive sync standard instead. It sucks to pay 25% of a monitors cost to some silly module that could have gone into better internals or more features or god forbid more than 2 connectivity options.
I'll have to disagree with much of the above. From initial release until today, G-Sync, thanks to the G-Sync module, has provided superior functionality and performance compared to Freesync.
At release, Freesync monitors couldn't even enable overdrive and Freesync simultaneously, making the monitors virtually useless as high performance gaming displays with Freesync enabled. Then, when Freesync monitors finally could use overdrive and Freesync simultaneously, the overdrive functionality only worked optimally near the max refresh rate. This is still the case over halfway through 2018! That's a stark contrast compared to G-Sync monitors which have had adaptive overdrive functionality from inception.
G-Sync also provides overclocked refresh rates, extended VRR ranges, superior performance at the VRR range boundaries, etc.
I'll gladly pay the "G-Sync tax" for the premium experience. It's unfortunate the 950G incorporates the first gen G-Sync module, but no doubt we'll see the updated module in future ultrawides.
Maybe we'll see some Freesync 2 monitors finally matching G-Sync's capabilities, but I'm not holding my breath for anything soon. From what I understand, it's up to the monitor manufacturers to individually implement the various features available.
Im in a situation where I can buy either. Is gsync better than freesync 2? FS2 looks a little more stringent in its standards.
.It mandates LFC and requires the monitor adds HDR support is all. Even if that support is complete rubbish. It doesn't give an experience anywhere near as polished as G-SYNC.
@Stu
The guy is correct it drops to 4:2:2, which is not that good for computer games as it crunches the colours.
Why? Simple maths. DP1.2 has maximum bandwidth of 17.28Gbit/s
3440x1440 100hz 8bit comes to 14.86Gbit/s
3440x1440 120hz 8bit comes to 17.82Gbit/s
3440x1440 144hz 8bit comes to 21.39Gbit/s
DP1.4 on the other hand goes to 25.92Gbit/s data to push even higher to 165hz without issue.
Could you please explain what you mean by "It doesn't give an experience anywhere near as polished as G-SYNC" ? Cause at first glance that statement looks like a bit rubbish to me but considering what you do for a living perhaps you would be so kind to indulge me/us in your perspective for this claim.
1) A few questions for you while we are at it. Does Freesync 2 not technically allow for the same kind of specifications to be met in a monitor as the latest and greatest HDR Gsync screens?
2) Presuming you are answering yes to this, is it then not down to manufacturers to decide how they go about said implementation?
3) and lastly, presuming you said yes to previous questions, isn't it then incorrect to say that a freesync 2 certified panel cannot offer, due to tech limitations, the same experience as a Gsync HDR monitor? even if there isn't one(freesync monitor) released right now with the same specs? in the end should it not be about monitor vs monitor and not Freesync vs Gsync?
Some of the 240Hz models and the LG 32GK950G vs. F reinforces this. Just wait for my review coming later today!
3340?I was just checking your maths, and I thought you'd do:
3340x1440x(8x3)x100hz for the bandwidth. If you do, you get roughly 11.9 GBit/s
Even at 144Hz you get 17.12 GBit/s
