I’d like to see 1180 around 700 mark if it’s dearer than that I’m not gettin one ..::
That is the absolute max I will pay and only then if it is noticeably better than a 1080tiI’d like to see 1180 around 700 mark if it’s dearer than that I’m not gettin one ..::
Hopefully it'll be around £550-600.
You would maybe get better results with a 8700K at 5.3GHz. 4.4GHz is weak
Also 8X MSAA does seem a little overkill at 2160p. That is more for potato resolutions like 1080p/1440p imo.
Generally speaking yes, but is this true for Crysis also? If so, then you are saying it is not cpu limited at 4K but GPU limited still?At 2160p you don't really need to go faster than 4.0 on the CPU even with extreme GPU setups as the most you are chasing is 60fps that the monitors support.![]()
By the way, I am referring to benching results for crysis specifically which as we discussed earlier was limited by the cpu.
Vanilla 980? Surely more than that... I thought the 980ti to 1080 was almost that.Was the last performance upgrade on the 980 to 1080 not 30%?
That is why I said you need a 8700K 5.3GHs (for bench results) Kaaps. LolIt is CPU limited @2160p but 60fps is easy to get, unfortunately for 1080p people want more than this.
It is a long time since I benched Crysis 1 but IIRC one of the reasons it is not good to look at is the fps are all over the place due to the CPU bottleneck. Crysis 3 on the overhand tends to have low and high fps close to the average as you can see from the example I did earlier.
Indeed. As a 4K gamer I would be more than happy with 2X MSAA.8xMSAA is overkill on anything over 1920x1080, Hell, even 4xMSAA is a bit overkill on 2560x1440 IMO.
^ Lol, wow. It looks like a graphics card.
But many people here must play games maxed out (otherwise what’s the point right?) so they would end up with low fps and then complain. Lol. What they don’t understand is after a certain point there is diminishing returns at 4K. You don’t necessarily need to max everything out at 4K to make it look great. As I have explained it a few times here now, things look better with less AA and on “Very High” settings at 4K compared to 1440p with more AA applied at “Ultra” settings.
Not referring to you btw Kaaps![]()
Don’t worry mate, you will have 1000 by the time the 1180 is out. Just keep on posting and talking about all this fake news and you will be there in no time.lol
it shows how desperate we all are for any crumbs of info . hopefully this time next month we will know where we stand, both on price, performance and lead times on getting in our hands..
btw just hit 500 posts... i was very excited to now get access to the classifieds forum............. when did it become 1000 posts!![]()
Haha! Indeed, preaching to the choir. Until we can power UHD sufficiently at high FPS i'll be at 2560x1440 with some AA
