The AMD Driver Thread
It just finished installing on a different drive but I get the same result, A Black screen, I went off made a cuppa and drunk most of it watching the telly then went to check it again and it's still on a black screen so I can rule out my impatience, I can't get the bugga to run.
Have you got any other software/overlay stuff running in the background? Try disabling anything and everything prior to launching the game.
Have you tried windowed mode instead of full screen?
Hi, I can't get into the game to make any changes.
Hi, The only thing on is the AMD software so I'll shut that down and see if it makes a difference. Back in a mo.
EDIT: That didn't help unfortunately, I did try with Relive turned off before but thought I'd try again now the installs fresh & on a new drive. There's nothing else I use. No Afterburner or Fraps etc.
Wow! AMD's new Raise the Game bundle makes a lot of gpu's look very tempting, All 3 games look quite good so there's a £100 saving on those which makes a £260 RX580 look like a bargain, Elsewhere you can get a £560 Vega 64 Nitro with the three games. I'm waiting to see if OCUK jump on board as the Vega 64 Red Devil at £530 would likely become very popular.
@nashathedog is the game loading through steam at all?
If so there is commands you can add the game launch options.
Link maybe helpful if your using steam
https://support.steampowered.com/kb_article.php?ref=1216-JMTZ-0860
And this one
https://steamcommunity.com/app/379720/discussions/0/1620599015894406714/
Just seems as simple as adding -windowed to the launch options for doom
I've tried all the different render commands etc that are linked over in the Steam threads but nothings helped. I read something about ultrawide issues but as suggested by Matt I've deleted all the user files.
I'm running Doom on an ultrawide, Vega 64 Win 10 so doubt that is the issue.
Have you tried a clean install of Win 10?
@nashathedog tested my V64 with Doom and no issues here also with 18.8.1
@LtMatt I believe there is some error with the displaying of VRAM usage in 18.8.1.
It displays that I am consuming 32GB VRAM minimum when playing Elite Dangerous :P
I have no performance issues etc. Still runs at 143fps cap on power save mode. (so clocks are between 1200 and 1384 and power consumption between 85W and 170W).
Wasn't there something about deleting the intro movies? Wait a few seconds after you reach the loading spot where the movies should be playing and then hit escape.
It displays that I am consuming 32GB VRAM minimum when playing Elite Dangerous :p
Yes it's a known issue. :)
what do i need to be able to use freesync without the light flicker it introduces?
what light flickering? Some times the issue exist these days if you use 3rd party overlays.
Whats your monitor, and what is your cable. Is it DP1.2 certified or the one came with the monitor?
Hi, I did one not that long ago (when I changed to a 2700x) And I've only just managed to get everything running how I like it, ie the right software stuff and I don't really want to do that again as I don't see why that would be the issue when everything else is working fine.
Hi, It's baffling me, I'm running an RX480 at the mo.
Hi, I tried the escape spamming but nothing changed I'll try and find info on how and where the movie deletes are done. Cheers.
my monitor is a really cheap one but seems good for everything doesnt flicker at all without freesync. there is a thread in monitors with my monitor the electriq 3440-1440 100hs freesync (it no longer does 100hz).
the dp cable is a fairly decent 1 i bought a while ago. made sure it wasnt some cheap rubbish.
The "cheap rubbish" and "expensive capable" mean nothing.
It has to be DP1.2 rated otherwise doesn't work properly.
Also given that we are in 2018 make sure you buy DP1.4 rated cable like the Club 3d DisplayPort 1.4 HBR3. It costs £13 (don't pay more than £15 for it) for the 2m one and kinda pointless to buy 1.2 these days as all new Freesync 2 monitors are coming with DP1.4 now starting with the LG 34GK950F
this is the cable i got, it doesnt mention what it is or anything.
maybe i should look for something better?
I think the escape spamming thing only works if you delete the into movies. I am not sure if you just delete the movies or remove the movie folder completely. It's annoying me because I had the same problem with the black screen thing and it was the movies thing that fixed it. But, it's all a blur what exactly I did because I was trying loads of different things, hoping something would actually work and let me play the damn game!! :p
Must say I like the new settings overlay with the 18.8.1.
Can change the graphics and colour settings ingame :D
