That is one fad i reeeeaaaaaally don't follow.
And i've got a room full of pop culture crap.
Bought a new Xbox for the front room...... waiting for tomb raider to come out.
Posty was a little rough with the parcel it looks like but everything is fine
Did he try to jam it through the letterbox!?![]()
Can confirm ice thing is useless- idea is great and fun, but the plastic insert tube is cheap and doesnt seal against the rubber very well so the water you put into the mould just leaks into the internal barrel bit. i imagine if you fitted an O-Ring of sorts, it would be fine. But I think i'll just return it
Tidy looking Case that and MX make cracking loaders. How much was it if you dont mind me asking?
It's 40 KPH.
The fatmax range used to look totally different to the dewalt range, but it looks like they're modeling the fatmax to closely resemble the Dewalt range now. Looks like the batteries might even be interchangeable?Stanley owns Dewalt so I imagine the Fatmax is probably a rebranded consumer grade Dewalt?
Waited 2 years for this
What do you think of the hot tub now you had it for a while ?Wife came home with this stuffed in the car
Now it’s down to me to work out things like pH levels and adding salt in the water
