chronic do 1080 res with your card. then post your fps. he dont believe me regardless of what i post.locky posted his.others have. still dont believe you can maintain 144fps
nvm. bored now
my fps on a 1070
i7 6500k
@ 1080p?
Yes sir, textures and anti on high everything else low.
Someone disproved your point now you changing the goalposts? Give overWhy aren’t you getting 200 FPS then ?
State of gamers these days, complaining when you only get 90fps, we used to be happy with double figures on Doom.
I've a 1080 and ryzen 1600 and my fps is all over the place, similar to youdsy.
All settings low apart from AA and view distance. while I do see 144fps and above it certainly isn't the average.
Trouble is trying to find a reason why?
Serious question, if you have a 1080 why are you running on low settings?
Been away for 10 days and they have deffo tweaked something fps wise in the latest patch as now seeing mid 200’s on a 1080Ti at 1440p (using pretty much the same settings as Grim / MarkA). It does drop below 200 at points. Afterburner showing GPU usage peaking at 98%.
Watch it youdsy will say you're lying.
This game runs better smoother for me at the max refresh rate of my monitor no matter what the situation is. They have for sure improved the games performance over the last few patches.
