PLAYERUNKNOWN'S BATTLEGROUNDS - Thread
I just got a solo CD in squads. Got 20 kills !!
Not very smooth. Worst its been for a while on my end.
That section of Yasnaya drops FPS for everyone in in the Squad I play with. Walk about 5 yards past the church and the FPS tanks. Also if you go into that building you are standing on and look in any direction from the roof the frames take a beating.
Yeah its the game. DG & locky state otherwise.
Any one else getting some weird issue where people teleport as they run?
It's happened a few times now where if I see someone running in an open field or town and they "judder" along with big gaps between like they are teleporting.
I don't think its a hack, more of server lag or something. Obviously it makes it impossible to hit them.
There's no point arguing the fps point as people have different expectations around the words used. For some, locked is 95% x amount of fps where unless you looked at a frame counter continually you may not see it actually drops from a high fps by 10%+ at times. For others, locked is literally 100% always x amount of fps regardless. It's the same argument as 30fps is playable on console, define 'playable'. Is it when you're used to only a max of 60 fps or is it when your used to 120fps and gsync/freesync. One says playable, the other says borderline abysmal. Different expectations.
Just the usual dribble. Go record a small squad game landing in Yasnaya and loot the area near the police station/hospital and lets see the FPS. A lot of the original map has large dips like this because they just copy and pasted assets without optimising. Sanhok should be a lot better and they learned lessons when designing Miramar also.
getting this back on track.....
Good games today boys - was very funny getting into the same server as each other. 3 games between us all and 3 OcUK wins.....,.
So is it the game or is there a problem with my PC?
Some areas you will get FPS drops. Especially on the first map Erangel. Large areas like Yasnaya and George really struggle with all the buildings. There are also some video of random FPS drops on Sanhok. I've also noticed since the re-introduction of the Weather to Miramar / Erangel (rain in paticular) FPS is affected.
We seem to be talking apples and pears. Youldsy started this off saying he couldn't maintain 100fps at 720p on a 1080ti which to me reads as I can't even average 100. Now that's description has changed to minimum frame rates tank in certain areas of certain maps. Clearly some areas are more graphically intensive and you will get drops - show me a multiplayer game with similar map size and player count where the FPS is rock solid at max rate (where no lower limit is set). PUBG is by no means perfect but if you go around watching minimum framerates the entire game you are always gonna find something to pick holes on.
