My bedroom measures 4m x 10m and is by no means big. Thats about 40 times the volume of a car.
Eh? That is massive for a bedroom, it's basically the size of a typical 1 bedroom flat!
Can you quantify 'a lot'? Our monthly bill for gas and elec is £105 (couldn't be sure how it's split) and I don't think it really varies that much through the year. In the winter I guess gas is higher for the heating and in the summer I guess the air con replaces the heating costs.
If I say take out a ac from a car even if it cools a room down a bit using 12v its still better that using nothing and it might take longer to cool the room down but its still better than using nothing
Yeah, you need a more efficient air con it it costs 130€ a month...
Erm from my understanding car AC units are usually driven off the engine, not electric (at least not for the compressor).If I say take out a ac from a car even if it cools a room down a bit using 12v its still better that using nothing and it might take longer to cool the room down but its still better than using nothing
Proper split unit AC is a lot cheaper to run than portable ones, as the portable ones blow heated air from the room out via the vent hose, which means that it's replacing that heated air with air that is at ambient temp that is being sucked into the room, whilst a split unit recirculates the already cooled air in the room, and uses an external radiator which heats up air outside the room (it's pumping the refrigerant between the room cooler and the compressor and radiator outside).It costs a lot to run aircon though, or mines just isn't very efficient.
We ended up running 2 portable units for most of every day for much of the last few months, it was expensive (around £7-10 a day), enough so that I'm seriously looking at getting a couple of split units for next year as they'll probably pay for themselves within a couple of years if we get anything like the weather we had this year.
- homes
- the workplace
- buses
