- 10 Apr 2004
I was originally going to source myself a 30" 2560x1600 monitor to upgrade from my Hazro HZ27WD.
But after some research (and plugging my PC into my 4K TV!) I think a 32" 4K would be better.
Therefore I'm currently debating if I should get the LG 32UD59, Samsung U32H850 or splash out on the 32UD89.
Given the panel differences between the 32UD59 (VA) and 89 (IPS), would I really notice unless they were side by side? I'm edging towards the IPS as at 32" towards the edges you may start to get color shift given the perspective?
I've spent hours going over panel differences, etc. It'll be used for a mix of things (Photography, Gaming, "office" work with two documents next to each other, etc..).
Must have requirements are:
Freesync
32"
4K
DDC/CI support (Brightness/Contrast/etc) can be controlled via software.
Decent warranty behind it.
Otherwise just a decent panel with good colour/contrast properties.
Thoughts?
Cheers.
Freesync
32"
4K
Thoughts?
Cheers.
