- 2 Aug 2016
In the past 5 years, I’ve probably had close to 25 cases, including the original and OCUK Airflow editions of the Evolv. This Evolv X is by the far the best case I have ever owned.
@HoneyBadger know what you mean mate. Been building PCs since the early 90s and the case was ludicrously easy to build in, keep tidy and looks great.
Just a question folks - Looking to vertically mount my GPU, but appears to be two options in the low profile and Bracket + cable. Anyone know if the bracket is actually required? Seems overkill as there is one on the case already?
I do however have an issue with this case - While the cable covers enable you to mount SSDs, I don't feel that SATA cables are appropriate to use. The straight ones fit, but when closing the covers it's putting pressure on the drives connector - which is asking for it to be damaged. You also can't use 90deg ones as they're going the wrong way. I feel it needs either:
a. Central sata adapter
b. 90deg adapter but doing up not down
That way, you're releasing the pressure on the drives connector. The left hand cover is worse than the bottom.
@ChugNorris This may be useful info for Phanteks in regards to future designs![]()
Available in 1000W and 1200W flavours, I have VERY LIMITED initial stocks arriving, so if you're interested, I'd suggest preordering ASAP.already poked our designer@Phanteks_Care might be interested to hear too![]()
very nice, hope you had a good holiday sir and welcome backNow available for preorder are the hotly anticipated Phanteks Revolt X Power Supplies. These are ideal for anyone planning to build a dual system into the Evolv X (or any other dual system compatible case such as the Mini-XL and some Lian-Li cases to name a few), as they enable you to power two motherboards with one unit, using their patented state of the art internal PCB. Added to that they are 80 Plus Platinum Certified, fully modular, with 12 years warranty and based on the Seasonic Prime Ultra platform. Essentially, all the right thingsAvailable in 1000W and 1200W flavours, I have VERY LIMITED initial stocks arriving, so if you're interested, I'd suggest preordering ASAP.
Phanteks Revolt X 1000W 80 Plus Platinum Modular Power Supply @ £214.99 inc VAT
Single PSU for dual motherboard systems, control each motherboard independently, manufactured from premium materials, 80 Plus Platinum certified
Only £214.99 inc VAT.
ORDER NOW
Phanteks Revolt X 1200W 80 Plus Platinum Modular Power Supply @ £234.95 inc VAT
Single PSU for dual motherboard systems, control each motherboard independently, manufactured from premium materials, 80 Plus Platinum certified.
Only £234.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
