Nice clean out work, get a Fuji or similar silicone profiling tool for the new bead.
Concave beads promote water retention and ultimately mould. You want a proper profile which sheds the water away.
Last weekend and this weekend, sealed garage floor and walls before painting. Also a chance to clear out some rubbish. Going to get a quote for running electric to it and get a roller door (possibly electric one) to replace the original 1970s up & over.
You might struggle to fit that tool behind the tap.
Masking gives a clean edge but when you lift the tape it doesn't leave a particularly flush finish against the tile.
Using your finger creates a concave profile which again tends to trap water rather than shed it.
This video is explains it well -
Thanks Sin Chase. Yep, I had just watched that video and it explained exactly what you were saying about concave. I just went out and bought this
Putting it against the joint, the smallest angle seems to be the one to use. I believe I need to turn the bevelled face the other way around from in my photos and run the flat face in the direction of travel.
I'm a little worried about not using masking tape which he says not to use, and I can see why. I just hope I don't get excess smeared where it shouldn't be. I'm going to cut the nozzle at 90 degrees to the size of the tool profile and hope for the best. Wish I had something to practise on first as I've never done it before and don't want to mess it up and have to spend ages removing it. Maybe the inside joints of a cardboard box would work.
	You just want a good laugh after I botch itPost up the results once you're done
Cut the nozzle at a right angle, don't use the nozzle to shape the bead. If you profile is a 5mm then cut the nozzle to 5mm also.
Make sure the area is clean but don't spray anything down prior to to application (like soapy water etc)
Run the bead ensuring its filling the gap then use the profile tool.
Keeping it flush against the tile with pressure is key to wiping off the excess. Don't feel like you need to do it in one swipe. Do small sections and clean the excess off the tool frequently. Overspill is what causes the mess. Be careful traversing grout lines as unless the tool you have has skids it will dig in.
Don't worry, if you mess it up up you can always clean it up out when wet and do it again!
 Got nothing to practise on though so I'll be going for broke.
