That moment nVidia realises there is a fatal flaw with all Turing cards...
Disco light artifacts
Quite a few reports of this on reddit also. Most people have RMA'd their card and had a replacement there the next day, so definitely worth getting in contact with their support! Seems like some very bad quality control for the price!Well, I think my 2080Ti FE is almost dead. Lasted a week with random application crashing, and now it's circling the drain with white block/space invader artifacts even on the desktop shortly after boot before it takes the whole system down a few seconds later.
Going to be having a word with nVidia's customer service. Expected better from a £1.1k card!![]()
Disco light artifacts![]()
While it was said tongue in cheek sort of I'm starting to wonder with some of the reports I'm hearing of the same failures with snow like corruption.
Received my 2080 Ti FE today. Just powered it up and to my horror, one of the fans is defective. What I can only describe as a constant brushing sound as if the bearing is catching on something.
You can really tell Nvidia are pushing these out as fast as possible. No QC.
Returning it for a refund.
Sucky![]()
Can anyone help, I've just received and installed my 2080 ti, booted into windows fine but in low res so I downloaded the latest geforce drivers. Tried to install the driver but it failed saying another installation was running. So then I tried to use ddu, this also wouldn't run and said my system had an update and needed to be restarted So I restarted windows which said update and restart. When windows restarted the gpu fans went to maximum and I lost the display.ive tried resetting the system multiple times and now all I get is no signal, max fans on the gpu and the vga light on my mobo. Please help!
I'm sure there's probably a lot of confirmation bias happening here tbh, but it doesn't look good.Wow looks like a huge failure rate?
Anyone else here with a 5820k on an Asus x99 pro? Since the windows update my new 2080ti won't work in the top pci-e slot so I can only use 8x
There was one of the Intel/MS updates that patched against one of the Meltdown/Spectre type vulnerabilities that were causing people a lot of problems like that you might need to remove it - was causing inability to overclock and problems with PCI-e compatibility, etc.
