Aren't you going to use the block on the reference card?
Is not compatible the Nitro & Reference block. Already got a new block for reference.
@Panos Here you go mate, those settings you wished for. Hope they get you up to 27.5KClick link for big one.
I see.Is not compatible the Nitro & Reference block. Already got a new block for reference.
This is the best so far!The reference took the settings without complaining.....
https://www.3dmark.com/3dm/30011584
Total 21997
Graphics 27390
Physics 16503
Combined 11126
In a warm room with the Predator on quiet mode...
Edit. Just realised broke the Graphics score....
Damn the 8600K needs a push..... Need to check RAM subtimings and see if I can do 5.3Ghz
If only I could do 1180 on the HBM...The reference took the settings without complaining.....
Total 21997
Graphics 27390
Physics 16503
Combined 11126
Shame I do not have better CPU. But I believe can do 27500+ with some tweaking. Which card you have and what is the HBM voltage reported in HWInfo?If only I could do 1180 on the HBM...
Total 21997
Graphics 27390
Physics 16503
Combined 11126
I am going to run a full run on all benchmarks todayGreat result, I did think reference have better hbm2. What do you get in the extreme (next fs level up)
after tweaking the subtimings on my ram.The reference took the settings without complaining.....
Total 21997
Graphics 27390
Physics 16503
Combined 11126
Here are my thoughts having stripped 2 Vega 64s.
a) The stock paste is thick like cement (feels like Intel TIM but less crumbly), not covering fully the HBM or cores due to it's thicker than usual substance. (Same applies to Nvidia cards)
The paste needs to be thick on the HBM as it isn't quite level with the GPU chip. They should really have thought about that when shaping the heatsink.
Brilliant mate, well done. I was hoping you could get past me. I did try 1200mhz on the HBM when I posted that big score, but I got artifacting during the run, 1180mhz I think is as much as I can push it.
The annoying thing is, I can bench at 1802mhz (1780mhz actual) but at 1050mhz on the HBM. Anything higher on the HBM at those ceiling core speed and it crashes. I found Vega doesn't like both core and memory at it's absolute screaming limit, although you can get away with one being there. Which is why I went with a higher HBM speeds and a very good (not incredible) core overclock works best for bench score. I think the benefit of having higher HBM speed for more bandwidth is better than jumping from 1750mhz to 1800mhz on the core.
@Panos Just looked at a compare. https://www.3dmark.com/compare/fs/16938414/fs/16741526#
It's quite interesting how your combined is 350 points higher yet you only have a 1fps increase in graphics test1. I wonder where that big leap comes from in the combined.
Yeah I see that but my point is, I wonder where the boost in combined score came from? It can't be from the CPU being at 5.1ghz compared to my 5ghz as in the physics tests and score obviously the 8700k is higher. So what's upping that combined score in the test I wonder?
