Man of Honour
- 8 Nov 2007
- Outer Space
Not enough screens
I got 1080ti up to 2ghz. So i going to need all resources to ran my new monitor at ULTRA 120hz AAA games. What Gpu/fps you got? Is monitor good for gaming?Hah. Ya. I need a 3 monitor setup for work. 2 to display images and the third for researching references, data entry, and detailed info on the images. Ultrawide is pretty nice to have for that too.
Ya. 3 take up more resources but in desktop mode it is nothing a gaming graphics card can’t handle.
Not a top tier pro gamer, so that's why I may not really care not having G sync.
does anyone know why the price on the store page is different than the one in the basket? https://www.overclockers.co.uk/lg-3...-curved-widescreen-led-monitor-mo-14x-lg.html
£1,099.99 * in the store pageThe prices are the same to me - £1099.99. What are you seeing? Unless you qualify for free shipping when you go into your basket you will have an added shipping charge of £11.70 for the pre-selected delivery type. That will increase the total basket value to £1,111.69.
If you do not want to use profiles on this monitor, how accurate can you get the colours using just the OSD controls? Are they going to be wildly over saturated when using the OSD controls and your only option would be an ICC profile? Or is it possible to get them half decent using the available OSD?
Does seem odd how you can only use the DCIp3 colour space with this monitor and how it is so over saturated in colours, considering this is not an actual HDR monitor it seems a bit odd overall. As I said above if you can get it to within maybe 5-10% over saturated using the OSD controls, that would be ok, but if it is anything near 30% then that is not very good.
@TFTcentral, why don't you include the section with "best available OSD settings" in your reviews anymore? That was very useful when you did that.
I think its crazy to say that the colors are wildly over-saturated. Out of the box, without calibration, the colors are fine. They looked great both on desktop tasks and gaming and I noticed no 'neon' effects.. I think the wide gamut displaying sRGB thing is overblown and love the way this monitor looks in game and in daily use.
Yes, this monitor is awesome in games. And yes your 1080ti will perform well. I just got a 2080 ti to pair with this but I needed a new video card anyway.
Is it possible that the Shop prices are listed in pounds while the basket prices are listed in € for you?£1,099.99 * in the store page
1,227 in the basket. it keeps changing
you can't alter the 950G's colour space using the OSD at all, it will only impact things like the gamma curve (via gamma setting) and white point/colour temp (via the RGB controls or colour temp presets). The actual underlying colour space will not change and so you will always be operating with ~135% sRGB coverage and so have some over-saturation compared with the sRGB colour space. The "best OSD settings" can be found in the calibration section of the review, those are optimal with or without the ICC profile being active, at least on the sample and system we had
yes it will be related to the G-sync module hereIs the lack of sRGB mode something that is attributed to some sort of limitation placed on the panel by the G-Sync module? Does the way it is implemented prevent this being available as a setting?
What do you think about the colours using the optimal OSD settings and no ICC profile? Would you say they are very over saturated? Is this is a big problem? Or are the colours reasonably accurate using the OSD settings?
Does seem weird to release a monitor like this if the colours are very incorrect, I assume because the Gsync module and the fact it is a DCIP3 panel, they did not have any other option. As ICC profiles do not apply properly to anything other than desktop colours or ICC compatible apps, if the colours are 30% over saturated this would be a problem.
Are the colours literally 30% over saturated from SRGB when using the OSD settings? For example rec 709 / SRGB 100% red, would be DCIP3 100% red ?
