- 26 Nov 2009
Hi, can the unit be run with fan permanently on and, if so, how noisy would it be? Would it then run at full speed or would there still be fan control?
All the info is on the Seasonic site. I should have looked there first, sorry.
I've just heard the fan noise of a unit in NORMAL mode and it's not appealing, that would really bother me. I don't know if that's an isolated case or they all sound like that. I need the fan to be on all the time since it's the only fan in the case. Looks like it's going to be the be quiet! straight power or dark power pro.
Thanks for the suggestions.I can't answer that but it wouldn't be as noticeable once it was in the case and the side panel is on. Also most people would have their case more than 50cm from Earshot.
If you haven't already bought it and want a quieter unit then sure BeQuiet can be good, and there is also the Corsair RMi and Bitfenix Whisper. That one has an ugly 24 pin cable though so not the best if you want the cables to look good.
Hello,I've just heard the fan noise of a unit in NORMAL mode and it's not appealing, that would really bother me. I don't know if that's an isolated case or they all sound like that. I need the fan to be on all the time since it's the only fan in the case. Looks like it's going to be the be quiet! straight power or dark power pro.
I've just been through three units. An ultra gold prime. And two ultra platinum 650w. Every single one had the exact same noise. All bought from different retailers. Looking at the few YouTube video everyone I've seen that's noticed this has also had it on replacement units.Hello,
This is not the usual fan noise and in this case, it's covered by the warranty. any issue with your warranty you can either contact your reseller or contact us for any assistance. We will gladly help you.
Thank you.
Best Regards,
I also came to the conclusion that this is the normal fan noise after hearing several units.I've just been through three units. An ultra gold prime. And two ultra platinum 650w. Every single one had the exact same noise. All bought from different retailers. Looking at the few YouTube video everyone I've seen that's noticed this has also had it on replacement units.
It seems very bad luck to have three in a row doesn't it? And I've not seen anyone that's had the issue where the replacement didn't.
I think this is just the fan noise. Unless the fan used has terrible QC. I switched to super flower which have silent fans. Going through three power supplies has been a headache and I won't be buying seasonic again. I've lost around £90 because of it.
It would have saved a lot of hassle and money if I was told it was just how the fans are. But every time a rep has replied to someone in a forum they've said it's not normal.
I think it's one of those noises that some hear and some don't. But I can hear it while gaming from 1 metre away and it's highly annoying.
Maybe it's an issue with the Focus line. The comments on this page suggest it's a common issue.I have never owned a Focus
Bought a be quiet psu instead and is very quiet due to its Silent Wings 3 fan.Can't you just leave the PSU in hybrid mode?
Yep I have an 850w Focus Plus Gold that I'm going to sell off - I like silence and the fan drove me mad, so swapped back to an EVGA unit - it's not 'faulty' as such so not going to bother paying postage to try and return a year old unit just to be messed about. All the early reviews and marketing about the silence of the unit just don't seem to be what us buyers later down the line have been experiencing. First Seasonic unit I've actually been disappointed to own.
Yeah I've bought seasonic for over 15 years. Always been great. These three prime units though all had the same "brrrr" noise toYep I have an 850w Focus Plus Gold that I'm going to sell off - I like silence and the fan drove me mad, so swapped back to an EVGA unit - it's not 'faulty' as such so not going to bother paying postage to try and return a year old unit just to be messed about. All the early reviews and marketing about the silence of the unit just don't seem to be what us buyers later down the line have been experiencing. First Seasonic unit I've actually been disappointed to own.
All three of mine could be heard over GPU and CPU fans which are smooth sounding, this noise sticks out and that's with headphones on as well while gaming. Just looking through Google there's tonnes of people with the same issue in the last couple of years. And it's the same noise every time they post a video/audioIf you run in hybrid mode that PSU should not even activate for regular computer usage, when it does activate your CPU and GPU fans should be more noisy.
