No electricity.
If the 2700X could do 4.2GHz all core at 1.00v then it would have a lower TDP. It can't so AMD gave it a higher TDP to allow it to hit the higher boost clocks.
Re-read what was said this is not about cost of running.
No electricity.
So if Intel can match AMD at a lower TDP and on larger lithography without better efficiency, how did they do it? Did they add some magic unicorn dust to their STIM?There is nothing efficient here, not even logically and mathematically.
Intel's 14nm++ is probably more efficient than GF's 12nm. Remember that Intel's headline node name is already more conservative than most other foundries and Coffee Lake Refresh is the 5th time they've used 14nm (Broadwell -> Skylake -> Kaby Lake -> Coffee Lake -> Coffee Lake Refresh). Although the names are similar, 14nm++ is a huge refinement on 14nm.So if Intel can match AMD at a lower TDP and on larger lithography without better efficiency, how did they do it? Did they add some magic unicorn dust to their STIM?
Logically speaking, and aside from the fact that no one talks about the cost of electricity when using the word 'efficient' on it's own, the actual cost of electricity is completely arbitrary and could be rendered negligible or vitally important on a political whim. Power efficiency is not arbitrary, and recognised universally to the same unwavering degree. It doesn't get much more mathematically sound.And £300 more expensive...... So it is not efficient when you have to spend all the electricity savings up front for the next 28 years, assuming both systems work at 100% load 24-7-365. If any less lets say 12 hours per day, that figure goes to 56 years.
Remember that only place where Intel was/is truthful is their process tech. 14nm is 14nm, even 10nm was 10nm, before it died under the weight of cobalt. TSMC, Samsung and GF use different metrics to name their processes and then they add a shovel of PR and we have 14nm, 16nm, 7nm, etc.
On paper Intels 10nm was very similar if not better in characteristics than TSMCs 7nm, because Intel was always very aggressive when developing and refining process tech. Now imagine you have all this experience working with single process for so many years now, you end up with miraculous 14nm++++++. Though at some point this won't be enough, well currently process already feels old in a way. I think 9900K is the pinnacle of their 14nm development, and next iteration if that arrives will see minimum gains, or even negative gains. 14nm can't compete with 7nm from foundries.
Look at the heat output of 9900K, its insane for Desktop CPUs, that's in a way a biproduct of sticking to 14nm for too long.
LOL you people are highly amusing
All i said was the hardware unboxed guy has some kind of agenda... i didn't attack him like it was claimed or question or argue or disagree with any of his data.. in fact i made NO comment at all about the content in his videos all i said is he has an agenda with some of his 9900k videos
what that agenda is who knows maybe he is trying to create controversy to get more views
maybe he is trying to gain favour with AMD fans and Ryzen owners so they sub to his channel who knows and when i really think about it i dont really care anyway
and searching my previous posts to see if i bought a 9900k or find out if i posted anything about the 95w TDP? seriously?
go ahead search away ill be interested to see what you find![]()
7nm EUV is technically 7nm+ or ++ depending on if they can pull it off so soon. I was comparing initial 7nm vs 10nm from intel.GF isn't going to do 7nm. And TSMC is already preparing for 7nm EUV in 2020 (Zen 3 and Apple). That's mile ahead than the 10nm.
What settings are people using for their 9900k overclocks?
I have seen (on reddit) everything from 5.3 @1.25 (throttled so not actually 5.3) and 5GHz at 1.2ish to 4.9GHz at over 1.35.
Sometimes this is with an AVX offset, and in some cases it isn't.
Der8auer suggests a -4 offset for AVX in his overclocking video.
If those of you with the 9900k could post your own settings/ experiences so i know what sort of ballpark frequency and voltage i should be going for (as well as avx offset) i would really appreciate it.
Thank you!Cinebench R15 stable with 4.7ghz cache and 4133mhz C12-11-11-28-1t memory
water temp of 24c
LLC6
set voltage is 0.04v lower than below actual voltages(max read voltages with HWmonitor)
5ghz 1.29v
5.1ghz 1.34v
5.2ghz 1.39v
5.3ghz 1.44v
running 24/7 rock solid 51/45/3600 1.35v max temp in game(BF4) with water approx 25c is around 59c
water temp of 24c
LLC6
5ghz 1.29v
5.1ghz 1.34v
5.2ghz 1.39v
5.3ghz 1.44v
This info is really helpful, thank you very much!i run my 24/7 settings with a -2 AVX offset and yes it passes prime 26.6 and any other synthetic. the benchmark settings i run 0 offset as theres no AVX!!
max XTU here http://hwbot.org/submission/3974322_nickolp1974_xtu_core_i9_9900k_3574_marks
How is your rig?Ramtest / HCI stable at those settings?![]()
What at 4133 12-11-11-28-1t you know it's not!!Ramtest / HCI stable at those settings?
You should aim for stability at 4000/4133 with the Gene, it can handle those speeds just fine. CAS16 should be possible with reasonable voltage (with the sticks you have).
Thank you!5ghz all core, no avx offset. Adaptive voltage loading at 1.296v GPU RTX 2080ti shares loop.
Hottest core:
Destiny 2: 59 (average 45-55) 1440p
1hr OCCT large: 62
1hr Prime95 avx: 85 (Coolest 79, may try reseat?)
All rads of the thicker variety. 360x2 + 240.
Haven't tried higher than 5ghz
How is your rig?
Is it still at 5GHz 1.25? I cant remember if you had an avx offset or not?
