I9 9900k
No not really, just seeing if it can be 100% stable and within acceptable temps <85c. Bit more testing to do but its looking highly possible. for me personally 5ghz is plenty for gaming etc.
That 85 degree figure is only when stressing the CPU isn't it? You wouldnt hit that often during everyday tasks unless your work software uses AVX?
yeah true but my cooling is not normal, basically a pump and a bucket of water. the previous test was done with the water just at ambient, pretty much like an AIO, room temp. Downside to bucket, it gets increasingly warmer. Upside, i can use tap water, about 7c and add ice, so i can get down to about 0c
So I have decided to change tack for now, wanted to see what the lowest voltage this chip requires to run all cores at 50ghz, something I have always done for my chips, quick 15 mins stress test in Realbench with 1.210v vcore in bios, same LLC7, under full load vcore was 1.154v and maxed at 1.199v. Not bad. Will be running the stress test for longer today to see how we go. Tried 1.200v but got the dreaded GSOD. But onwards and upwards as they say, lol.
Seems to be quite the variance in temps to vcore with 9900k. Interesting that your temps are very similar to mine at 5.0 but at 0.1v lower vcore.
After more testing for lowest vcore at x50 I had to up my core voltage by .5v to get Realbench Stress test to pass a 30 minute run, so vcore in bios was 1.215v, under full load this was 1.164v, so quite happy with that. So some kind of stability at a fairly low voltage, but will keep testing.
Deliding these chips gains you very little temps wise, there's a lot of info around the net about this. Intel should have gone back to solder TIM ages ago in my opinion.
I've seen the various reports on delidding from der8auer and silicon lottery, but i would be interested to hear if anyone has a delidded chip and how it clocks.
What would be even better would be to know benches, temps and clocks before and after to see if all the chips are seeing the same temp drops with delidding or if there is some variance (outside margin of error) in the quality of the STIM.
I agree with you that the gains don't seem great, and that STIM is an improvement.
That sounds like a really good cpu you've got.
Thanks, yes not too shabby.
Well I wanted to know how good the IMC is on my silicon, and not too bad I must say, I have a very good set of ram, Samsung B dies, a 3200mhz CL14 kit that will do 4133mhz CL16 on my Apex board, set timings and voltages manually and booted straight up.
with delid and lap should net around a 10c drop, for me my scaling is quite linear so another multi higher should be possible, so 5300mhz 24/7 and 5500mhz benchable.
so is it worth it, probably not for most, but for some, yes.
Pics!
After extensive testing at 50ghz, this chip will run quite happily at 1.164v under full load, max was 1.199 with my above bios settings of 1.215v set in the bios, LLC7, cache at 45 for now.
So now I am going back to my core overclocking, 52 was giving me a bit of gip temp wise.
How far did you take the voltage for 5.2 before you stopped?
Had a little play last night.
2x360 + 240 900rpm, 2080ti shares.
5.1ghz @ 1.309v
Hottest core
1hr OCCT large 65
Realbench 30 mins 74
~1.5hr Prime AVX 88
One thing annoying my ocd is the difference between hottest and coolest core. 88 prime but coolest 80. Reseated but nothing changed. But all in all, I am very happy with my OC.
How is the overclock? Still stable? Are you keeping it at 5.1 24/7?
1.350v if I remember correctly, it was the temps getting up towards 90c in the Realbench Stress tests that I was not happy with, although Intel do say the100c Tjunction can be upped to 115c, but I would not be happy getting up around those temps at all.
