- 6 Sep 2016
There's a pair of celestion A2 on gumtree. Originally £1600. You won't buy better speakers for the price. They are great speakers but 4ohm
As for matching versus non matching I would rather have higher quality non matching speakers, that inferior quality matching. Ie a while ago I had kef q75 speakers these were large floorstanders. The matching q speaker was the kef q9c. It was awful.
So i went for the kef model 200 reference. Non matching buy quality far exceeding the q9c. Also instead of just bring a two driver speaker it was a four driver speaker. Being physically bigger with more drivers wider frequency response higher max output it could keep up with the big q75's.
Dont think i brought this up but I was thinking of using table-top TV mount base like this:I thought I had seen bookshelf speakers on their site in the past. Can't seem to find them now, but possibly it's because I am browsing by phone.
You've written asking about lots of options in your various threads. I'm sure you've mentioned this kind of idea, though the first product you came across had an issue with toppling iirc.
In a smaller room and/or if you are close to side/rear walls I would go for bipoles. Regular speakers need distance behind you otherwise soundfield is too distracting. I've used monopole, bipole, and dipole side/surround speakers. Currently use bipole side, monopole rears but in previous room used dipole side with bipole rear then replaced dipoles with bipoles as sound tracka moved from matrix ed pro logic to discrete
Dipoles should be on the side wall at exactly 3 and 9 o clock position. Bipoles can be on side and rear wall. So you're going with 5.1 not 7.1?
Not sure kef make bipoles they only have dipoles.also there are differences between them. Bipoles have both faces in phase. Dipoles have one face out of phase, this faces the back wall. Tripole speakers also exist but m&k are only ones who make them.
"Pole" speakers are quite expensive if fact 2x more expensive than the identical fronts as they have 2x as many drivers. Or in case of nhp-2, 2.5 X times two treble, two mid, one bass.
I use definitive technology BP-2x for sides now, and used nht hdp-2 dipoles in past for sides. Got spare pair of BP-2x and hdp-2
The benefits of dedicated surround speakers is they are designed to be wall mounted, are slimmer in depth to similar monopole speaker and can provide a more diffused soundstage, as I said if you are close to speakers it's what I would use say 1.5m or less.
Celeation A1 on auction site. Original price was £900, so £200 is good price.
Anyway, if it works for you then go for it. You know the depth of your cabinet and the low you're trying to achieve.
I don't know if you'll need 12" of clearance though. That sounds a bit excessive.The Q650c is 8.25" tall. The front L & R speakers.should be on stands, so you shouldn't need clearance heght for those. I think if you allow 10" then you'll cover the speaker height and have some allowance for the pedestal thickness too.
I just wanted to say thanks for the help and to sorry for bieng a pain (im persistent what can i say) im on budget restraints for now so i can get a set up later. Thank you and have a lovely ChristmasYou've written asking about lots of options in your various threads. I'm sure you've mentioned this kind of idea, though the first product you came across had an issue with toppling iirc.
