Xbox one X owners how slient is your console and has the noise levels increased snice your purchase it. Any coil whine? Or crazy jet engine fans sound's
Mine's very quiet apart from playing RDR2 which makes it audible but not loud.
I tried to see if they would do a one off replacement for my elite pad (I'd read on-line they had done one off courtesy replacements for others out of warranty). The guy did say it was 1 year with them so worth trying if you're in that time frame. He just spent ages getting me to upload the receipt and try to do it through the console warranty, it was a waste of time.
I do wonder if it depends on who you speak to...
I have an elite pad plus Forza 4 reserved at Argos for £105 but I think I might just do a repair jobby on mine, needs new grips and the RB button replacing. Its a nice pad but you need a good warranty!
That seems a decent deal when you consider that even just buying Forza Horizon 4 is about that, especially with things like Crackdown 3 to come next year....
Yeh I said exactly the same thing to Microsoft but they were not interested. Just said sorry one year warranty and that’s it.Warranty should be irrelevant, you have a reasonable expectation that a 150 quid game controller will last more than a year. I'm pretty sure UK consumer rights are on your side here.
Yes a SSD will help with loads times on games like Forza significantly.Is and SSD upgrade worth it for loading times as I am finding Forza runs like a dog or would an external ssd be better?
Is it normal for the fan to sound like it is pulsating? Only tried it with FIFA and Rocket League, only heard this on FIFA and supposedly is a thing on enhanced games.
I've still got it on downloading at home, did FM7 and the end of fifa last night, ESO and FH4 today...
...perhaps the temperature when it's pulsating is sitting right on the limit between two fan speeds?
My X is a scorpio edition for reference...
Used externally though? You can't upgrade the Xbone's internal HDD can you?
No, you can't officially upgrade the internal drive.
Even an external SSD limited by USB 3.0 is still significantly faster than the internal drive though
Yes used externally. You can upgrade the internal but it means voiding your warranty and taking the console apart.Used externally though? You can't upgrade the Xbone's internal HDD can you?
Must be a bug I got surface pro yesterday and it said 2021 aswell, but the store says 1 yearwonder if you guys can do me a favour ?
has anyone registered their one x with microsoft as i did mine and it came back with some strange readings !
it said the following
Technical warranty expires 05/04/19
manufacture warranty expires 25/11/2021
That is 3 years! i went online to ms chat and the guy could not understand it and said "you should really have 1 year but its saying 3 so you have 3" (i have not taken out any special care).
He has emailed the chat log saying saying my 1x is covered for 3 years and thinks it maybe because its a special white robot edition which i think is bull tbh.
Logged back in today and the technical part has vanished which makes me wonder if the insides were an old returned 1x which has been repaired and a new robot white case put on and being sold as new ?
anyone check their warranty status please and see what you have
thanks
