If it's above a door opening, it could just be a filler piece or it could be a lintel. I'd suggest getting someone in to advise before just drilling through it
I guess, be a painting run through upstairs though as there's a bedroom and bathroom above. I contemplated about going I to the ceiling then across out the wall but I think there's a lot of pipe work under the floor boards above.
To be fair, I did stop at 4 50mm holes , although you could maybe make a fairly low profile 100mm square divertor/splitter plate/box to go over 4 50mm holes in a square pattern. The outlet grill is going to be a 100mm square anyway I;m guessing. You would run 50mm plastic pipe through the holes and seal around the inlet of course. so moist air doesn't meet wood.
Think galley kitchen, door down the end with a window next to it. Above window and door is about 30cm of space,all of this is wood, but not one solid piece
