I'm just stating a fact. All the top review sites say oleds are far better
I dont know which reviews you are reading but none say that OLED is 'far' better. Its your opinion that it is better, but it is just that.... an opinion.
Well bought the Q9F delay, getting delivered on Friday.
What TV do you have ?any reason why you picked this over the rest of the competition?
personally i think it's overpriced and the xf90 offers better VFM for similar PQ.
OLED offers better PQ for cheaper
at 65" size price differential between samsung and sony is smaller,
afaik it has 10x more dimmable areas too, more like dx902 had,
.. recently learned pan fx750 disappointingly has just 5 bars/areas, albeit IPS, but have not yet seen one though.
also - if you have had a partiucular brand of tv and are happy with the build quality/life you tend to be loyal - rtings don't discuss reliability/happiness, do they ?
Catch up on Vincent .. one of the few things worth watching on utube, whilst I'm finding nothing to watch on sky - 8x6 versus ~50010 x more dimmable areas? that sounds like BS to me. it would be substantially better then not 0.2 points overall if that was correct.
That surprised meXF90
https://www.rtings.com/tv/reviews/sony/x900f
which is like half the price of the Q9F but just as good
https://www.rtings.com/tv/tools/compare/sony-x900f-vs-samsung-q9fn/585/599
8.3/10 vs 8.5/10
i don't think the 0.2 increase in PQ warrants double the money
That surprised me
I was expecting you to come back saying you had a 65" or 77" LG C8 OLED
Got that bad boy set up yet? I was so close to buying that myself but grabbed the 65C8 instead.Well bought the Q9F delay, getting delivered on Friday.
I was extremely interested in the QF9. It seemed to be the first TV Samsung sat down and tried to make the best TV they could instead of trying to use gimmicks and style to outdo the competition.
Ended up making one of the best all round LCD TVs ever made.
It suffered from over agressive local dimming. I believe a firmware update came out to lessen the effect.According to that review and I only watched like a minute of it. So could be more.
The Q9 performs really badly in dark scenes missing a lot of detail. In particular when Sandra bullock is lost in space. It's amazing how much detail is lost compared with oled.
It is but Hdtvtest, Avforums and rtings are much better review sites.
What hifi make their money from promotion. So you can pay to get a better review.
Compared to last year’s 900 series, the 2018 X900F bumps up the number of local dimming zones in the LED backlight. In fact, it can almost match last year’s more expensive X930E (approx. 60 versus 72) but cannot match the flagship Z9D, which has more than 600 zones for local control. As a general rule of thumb, more zones offer improved luminance control and enable the TV to reproduce more contrast-rich pictures.
After the very disappointing performance from last year’s edge-lit Q9, Samsung has decided to once again incorporate an LCD panel with zone dimming – or so-called full array local dimming (FALD) – in Q9FN. In the US, the step-down Q8 will feature a scaled-down version of the backlight whereas the European Q8 will be edge-lit. The more affordable “QLED” LCDs will all be edge-lit. On the 65-inch Q9FN, we counted a total of 30x16 zones (480 in total) spread across the LCD panel, which means that each zone covers 17,280 pixels (8.3m pixels / 480 zones). In each zone, Q9FN can boost or dim its backlight in accordance to the specific movie scene. Samsung has declined to comment on the zone count in the smaller and larger TV sizes
That’s the problem with reviewers, they all have an agenda even though they won’t admit it. all you can do is look at each model your thinking of buying and try and make a decision based on what you see yourself, what I would say is try and view it at a shop like richer sounds that has a media room so your not seeing it in a shop environment, and the good thing about richer sounds they will move the tv your thinking of buying into the media room with some notice.To be fair, I did some digging (after I bought my lg b8) and Vincent at hdtvtest seems to be in bed with LG. He gets free travel to go to their events/product launches. He seems very knowledgeable and maybe he doesn't let the freebies bias his views...but eh, if I'd known it before I bought my tv I would have put a bit less stock in what he said.
Am the other wayi always buy bang for buck. i think it's stupid to spend more than £1K on a tv. every tv I have bought has been cheaper than £1K. all of them very very very good tv's usually one of the best available.
right now the XF90 is the FALD value for money king.
i would have gotten the 65 inch had it been cheaper than £1300 but it was £1500. so it made it not worth it over the 55 inch for me. would have been my first tv to break the £1K barrier but wasn't to be
Am the other way
As I look at TV's even with a high price tag give me really good value due to the amount of hours I use it for and the enjoyment I get from it and the amount of years I normally own one for (My last TV was 12 years and 34,000hour use)
plus the value added due to it something all my family members + friends will use it...
And when it does come time to upgrade it then the TV is normally passed to another room or family member...
