PHANTEKS EVOLV X & P600S
Any update on the 220mm riser please? Got a 200 quid order on standby waiting for one of these babies!
Looking at the tracking, currently arriving on Friday, however chances are it might come in a bit earlier. Once they are live I'll post in here (if I remember, it's absolute chaos here at the moment with the amount of orders!) :D
Thanks fingers crossed for the weekend!
I'm thinking of running my 280mm rad on the roof with the fans as intakes and installing a 580mm rad filter to stop as much dust as I can so that it blocks all the gaps on the top,this should be OK shouldn't it,I've got 2 140s on the front and a 140 on the rear.
Urgh. I ordered the poor man's version which is still out of stock
@ChugNorris is the other 220mm imminent please - is there a way to upgrade to the other one on my order if not?
Speak to CS and they'll swap it over or as you've pre-ordered cancel that and order the premium one.
can anyone let me know what extension/splitter will work with the case leds so I can attach them to my Asus Aurus enable mobo as I only have 2 headers for all my leds
Would need a female/female as my 2 extension cables only have male out to daisychain
Any ideas of such a thing or any other solution where I could control 2x 4pin rgb and 3x 3pin rgb leds from
Did this yesterday and now the enthoo 2.5 drive bays are out of stock which were also on the order. I would have thought oc would reserve your items for you at point of order but this is not the case. Hopefully will get shipped next week now.:(
I've had to wait for my riser cable, ordered it Wednesday still not shipped spoke to CS this morning and they've upgraded me to a Saturday delivery.
6 Days after ordering and it still hasn't left England yet. :rolleyes:
Can't spell "Derped" without DPD.
I just can't seem to align my motherboard properly in this case where as I'm having zero problems with the maker 5t. If I align the top two rows then th3 bottom row is misaligned. If I do somewhat manage to align them then I have to bend the motherboard just to get the screw in would this damage the motherboard
Wouldn't risk it, doesn't take much flexing of a board to damage traces in the pcb. Wonder if that's a manufacturing flaw in the case or just a slightly misaligned screw hole in the mobo? Hoping my crosshair hero vi fits fine =/
Can anyone tell me how to turn on the leds on the case if the mods button had been held in and turned them off by a lovely little daughter- I’m not with the case so can’t try anything
Fitted 6x noiseblockers 120mm for rads at top and front of case, kept the 140mm Phanteks for the rear.
