Amazingly, I have other components in my Rig than just a CPU and GPU...Why? Your GTX 1080 is 180W, how much power do you think that CPU will need? Definitely not 350-400W? lol
Which account for a not-so-significant amount of watts..
450W consumption from the components won't overload a 600W power supply.
In gaming there might not be instant problems.What happens if you put a 105W 2700X and overclock it? Will work properly but we will continue to spread myths?
People are ignoring it already with Intel chips.I know that everyone keeps ignoring the power curve after the overclocking, especially with AMD chips, but its there and the numbers are insane
but I do think my 600W 6 year old PSU will have to go
Yeah I know that. So a GTX 1080 and OC 16c/32t Ryzen 3 drawing 450W would be fine in beany's 600W PSU.
Unless he bought a cheap no-name Chinese death trap for a PSU which is probably only rated for 200W at less than 25 degrees and will explode if you even think about putting it under load.
my PSU is Corsair Gold, not a deathtrap model lol
That's the problem with becoming "too expert" in something. Your standards become so sqewed that nothing but the very very very best is good enough. I'd love a Ferrari 488 but I dare say for Lewis Hamilton it won't be enough and will feel slow.JonnyGURU would probably disagree with you there![]()
I know people are sold easy way on marketing bullshietLol,we had 125W and 140W TDP class CPUs in an era of worse PSUs,and many overclocked CPUs consume a lot of power anyway. I remember running my overclocked high VID Q6600 and overclocked HD5850 fine off a Shuttle SFF PSU fine.
Already 8700K was capable to seriously exceeding TDP without any user overclocking, if BIOS just chased after advertised boost clocks instead of strict following of advertised TDP.
9900K can go to 200W if cooling is capable to keeping temps under control to not limit boosting. (& 50% over TDP just in very real world Blender)
https://www.tomshardware.com/reviews/intel-core-i9-9900k-9th-gen-cpu,5847-11.html
Same here:
https://www.gamersnexus.net/guides/3389-intel-tdp-investigation-9900k-violating-turbo-duration-z390
Lots of those Intel overclockings people so proudly tout might well fall crashing down if stress tested thoroughly.
But high VRM temperature certainly has effect to lifespan of its capacitors making VRM fail faster because of them, if soemthing else doesn't break first.
With full all core/thread load like video encoding VRM would definitely overheat fast causing throttling.
Same here:
Whats your guys' opinions on this article?
https://www.extremetech.com/computi...mds-ryzen-3000-series-are-too-good-to-be-true
Apparently its just not possible for these rumours to be true based on a couple of different things, not sure how to take it! it could just be an intel fanboy but it does sound like he has some valid points, one of them being that the 3000 series Ryzen 3 is basically the 2000 series Ryzen 7, and its being sold for half the price? And everything beneath 6 cores is now no more? Im not sure, but its probably best to take all this information with just a grain of salt anyway
I had an FX9590, Crosshair ATX, Radeon HD7970, 16GB of DDR3, several hard drives, WC pump and fans all running on my Seasonic X-650.
Power at the wall running Prime and Heaven concurrently rarely exceeded 470 watts.
Nothing wrong with my 9.5 year old 700 W PSU. Even powers the hungry hungry Vega without issue. If anything, a Zen 2 setup would probably use less power.Well that's a totally different kettle of fish!
I've just bought a Corsair SF600 for exactly this reason; although my Silverstone ST45SF-G has run my 2500K and overclocked GTX Titan perfectly fine for 5 years, the project has shifted to a 6700K and I'm not overclocking with that 450W unit.
