- 11 Sep 2009
- France, Alsace
Thanks man, good feedback. The guy wants 250 for the pair.
Anyone using/use Xert?
Quite tempted by it myself, something to put some structure and guide what little training I have time for towards something...
Anyone know.
Rotor cranks. I have three sets of instructions and they all say different things regarding spacers. I no longer need the 11mm DS spacer due to the c bear BB. You also need some thin spacers, I think just for the adjustment nut to wind onto.
One set says 0.5mm on either side.
One says 1mm on NDS.
One says 1.2mm on NDS.
I think I have a 0.5 and a 1mm shim but would have to measure them.
I have assembled with no shims and have no lateral play currently and don’t need to wind the adjuster on the NDS in at all.....
Edit; I had a reply from C bear who said in my case no spacers needed.
Yeah no spacers on my bikes either. The c-bear bearing cover should be enough for the rotor adjuster to wind onto.
@Berger having a right old time eh?
Do not worry. It'll be glorious when it is finished. For summer 2020![]()
Those are placeholder rims for the Enves you've got on order right?![]()
I've broken the head off my left femur
Caught out by the ice this morning,
After a little accident, I've broken the head off my left femur off so I've had it wired & screwed back into place.
Hoping that does the job, otherwise is a full hip replacement later next year.
Looking at at least 6 months off the bike![]()
