Sorry to ask, and you probably have done this already, have you set windows Display monitor settings to the correct resolution and Hertz?
Right click Destop
Display settings
Select the monitor
Advanced display settings
Display Adaptor properties for display
List All Modes
Scroll and select correct resolution and hz
Try that
Also, try the same resolution but with 120hz?
the flickering might be caused because of the 144hz - sounds silly but I have seen a few post with that issue.
Yeah, I went into the monitor settings and changed it to "2560 by 1440, True Colour (32 bit), 144 Hertz" (to be honest I couldn't see anything in the Radeon control panel that let me change it in there!)
Either way I've tried using all the different refresh rates (60, 100, 120 and 144) and the only mode that didn't produce the flickering was the 60hz mode - although the first suggestion in my other thread was to try a different displayport cable - I happen to have one and am in the process of testing it with that right now - so far *crosses fingers* I've not noticed any flickering/corruption/artifacting!
My only issue now is the cable I'm using is about 3m long whereas it doesn't need to be more than a metre!
