- 29 Feb 2012
- London
Anyone?????
I'm running 420 EK in the front and an EK 280 in the top with Silentwings 3 fans on the front and the Phanteks ones that came with the case on the top one. I know its overkill for my kit, but without cranking the fans up, the 420 was struggling on it's own.Just assembling the last parts for my first hardline build in the evolv x. In terms of rad size, placement and brand, is there any perceived wisdom / advice that people can offer me?
It will be a 9900k / 2080 TI FTW3 build on a formula XI.
I've just started to build mine. Gonna use XSPC EX420 with Noctua NF F12 ippc2000 in the front and Alphacool Nexxxos ST30 280 X-Flow with Phanteks fans up topJust assembling the last parts for my first hardline build in the evolv x. In terms of rad size, placement and brand, is there any perceived wisdom / advice that people can offer me?
Here’s the final incarnation of my build.
Think I’m decided on 2 x HWLabs GTS360. Any good RGB fans to go with these (ideally aura sync compatible)?
Ive
I’m going for the Thermaltake riing trio fans with mine
Exactly what I did
It’s you!!!! It’s been agessss hope you’re well!
How are the fans in action?
haha
yeah man, I'm good thanks. You all good?
They're ok actually. I kept my Vipers on the front as they shift some serious air but the RIINGs are on the AIOs.
Do we have any hints at what the P600s is gonna end up with? Rad support, features etc?
