It’s a 100% legit site and the torches are not £1 mass made crap. Even if they were mass made they’re no different to iPhones etc that are manufacturered in China.
Granted there is some tat on there, but it’s priced appropriately and you know what you’re getting.
Hi all, need a small, simple torch that I can hold in my mouth whilst I'm working on the computer and the like
Also want it for other purposes too
So brighter the better
Just get a little Olight i3E. They're only a tenner and run off AAA's. I have one on my keyring and it's very handy when rummaging around inside my PC.
Anyone suggest something that fits the following:
Small <100mm
Zoom
Can be charged by USB or use AA/AAA
Waterproof
Upto £30
I've had a couple from Amazon but have all failed after a short while. Need it before I go away in a couple of weeks, so ordering from China might not be an option...
Anyone bought Nitecore products via www.nitecore.co.uk? Can't find any reviews or feedback suggesting its a legit dealer for Nitecore products. Regards
