Absolutely! This just lets the card draw more power if it needs it. Slide it to 120%, click apply then run the scanner. Press test when it’s done then save to a number. I would run with just the core overclock for a bit and once you know it’s stable fiddle with the memory.
Thanks mate. Might eventually do this if by the summer 7nm looks like it is far away. End of the day I do not see myself upgrading until Cyberpunk 2077 is out anyway.I paid full price for the Titan cooler and the 280 CPU was a alphacool refurb £50.
Watch Gamers Nexus video on how to strip down a Titan X Pascal.
Nvidia’s API that makes it possible, Afterburner just plug it in.Why is the title nvidia's gift? I thought this was MSI/Afterburner's software? Also i don't get anywhere near my manual overclock using this. Max power settings unlocked temp limit from power limit too.
i thought nvidia released the api but msi didn't include pascal gpu support or recognised them but now have released updated afterburner. That's what i interpreted. So thank MSI for the update? which Turing cards previously had.Nvidia’s API that makes it possible, Afterburner just plug it in.
How come all of you are getting such high numbers? Mine was only 69MHz.![]()
Ran it on my ASUS GL703GS laptop which resulted in the following curve for the 1070 -
How do you save the voktage curve without the curve adjusting itself to an unstable curve autonautomati
Sounds odd that you are getting 69MHz as the OC scanner adjusts the graph rather than just one overall adjustment.
Just hit the save icon then the profile number.
Shouldn't that be +0So I ran it again with all the suggested settings. As you can see average overclock is 78MHz.
I notice it started off at +88.Shouldn't that be +0
What base clock does it start off at?
It should start off at whatever is default for the card.
Don't believe the +xxx number as when it is below the base clock, that number doesn't make any sense. It is only when it gets to the latter stages it becomes realistic. Mine shows +191 for example in the early stages, which definitely isn't correct.
Your dominant limiter seems to be "No Load" which is wrong. It should be Power or Voltage. Check you other charts to see what is going on.
Yeh I don't believe that. The limiter for unmodded cards should always be Power/Voltage.
For me it is Power (1080ti) even at 120%. There is also another user who posted Power above.
