- 3 Nov 2004
- UK
Think about mounting the res/pump combo on the front rad, works well. Take a look at mine for clearance, D5 with a 150mm res.I'd like to go with the Aquacomputer D5 Next Pump with a Watercool Heatkiller D5 tube Res.
Just wondering what my mounting options are in this case and whether to go with 100, 150 or 200 size for the res. My first loop build so I'm puzzled by whether I'd mount the whole lot with a stand or whether using the res mounting holes is the way to go?
https://www.overclockers.co.uk/aqua-computer-d5-next-rgb-smart-pump-wc-32x-aq.html
https://www.overclockers.co.uk/wate...be-reservoir-for-d5-pump-black-wc-10k-wc.html
