- 8 Apr 2015
- Normally in the car
Got excited when I saw it had G-Sync, then deflated when I saw the launch timeline, lol.
Good things come to those who wait
If the monitor is using the same panel as the 34GK950, which is a panel that is already in mass production, one would think that it shouldn't take same long Q3-4 time frame to get it ready for consumer selling, as it did with the 34GK950? But you know more than us, so I will take your word for it.
So apologies if this repeats any info, but here are some specs I can release for this model;
38" Ultrawide 3840x1600 Res
450 nits
DCI-P3 98% coverage from Nano-IPS display (I think)
HDMI, DP & USB
G-Sync
144Hz
Sphere Lighting (like on 32GK850G and 34GK950G)
Dynamic Action Sync, Black Stabilizer
How about monitor dimensions? Too early or can you dig those up (without stand pls!!)
450 nits
HDMI, DP & USB
G-Sync
144Hz
In regard to HDR:
nVidia's older v1 G-SYNC module is limited to 3440x1440@120Hz. Even if a 3440x1440 G-SYNC monitor includes a panel that can reach beyond 120 Hz, the v1 G-SYNC module will limit the monitor to 120 Hz regardless (see 34GK950G).
It follows that 3840x1600@144Hz (as supported by the 38GL950G) is beyond the capabilities of the v1 G-SYNC module, meaning this monitor will ship with the newer v2 G-SYNC module. The v2 G-SYNC module supports HDR (or more precisely, the v2 G-SYNC module supports the HDR10 protocol).
If a monitor combines a newer panel with a HDR10 capable controller, then nothing prevents the manufacturer from at least slapping a DisplayHDR 400 badge on it. Combining this panel with the v2 G-SYNC module already provides LG with everything that is necessary to achieve that HDR certification level and it does so without LG having to invest a penny more into engineering.
Two assumptions:
Without a FALD backlight a DisplayHDR 1000 certification is off the table. LG might go with a DisplayHDR 600 or 400 certification, or forgo the official VESA certifications entirely and just slap their own "HDR capable" badge on it. If the above two assumptions are true, then LG is practically guaranteed to go with one of those options. That this monitor, with a v2 G-SYNC module, isn't at least marketed as "HDR capable" is almost unthinkable.
- nVidia doesn't release an entirely new revision of their v1 DP1.2 G-SYNC module that supports 3840x1600@144Hz (in theory DP1.2 does provide enough bandwidth to drive that resolution and refresh rate, but DP1.2 doesn't support HDR10).
- LG won't pass up, for no reason, on the marketing opportunity to slap a HDR badge on any monitor that deserves it.
Of course DisplayHDR 400 shouldn't be taken seriously. Even DisplayHDR 600 barely deserves to be called HDR, but that is a different topic.
I think we'll start to see microwaves marketed as HDR soon. The whole thing is a complete joke to be honest. Most people on this forum are wise to it of course, but the majority of consumers are not and it only gives the greenlight to manufacturers to whack a premium on every 'HDR' product they sell.
I find it laughable that VESA claim to be a non-profit organisation... there is little doubt in my mind that some fat envelopes were passed underneath the table in order to get these so called 'standards' pushed through. The only ones that benefit are the manufacturers themselves. It's a sad state of affairs really.![]()
personally I think it will be too challenging to get HDR working with Gsync and so will be left off in any meaningful way here
That statement makes no sense. The v2 G-SYNC module was built specifically to support HDR. nVidia literally calls it their G-SYNC HDR module. That module represents a turnkey solution which monitor OEMs can just plop into their monitor. At that point there is literally NOTHING left for the OEM to do in order for HDR to work in tandem with G-SYNC. That is the opposite of challenging.
As stated above, any half decent monitor (and most definitely a semi professional monitor like this one) incorporating the v2 module will support HDR and G-SYNC by default. Whether it deserves to be called HDR is a separate, marketing related issue.
I'm unaware of the existence of a separate non-FALD version of the v2 G-SYNC module. AFAIK there is only ONE such v2 module. In monitors without a FALD backlight, the wiring that would carry the signals to control the FALD backlight is simply omitted.
Agreed. This is unrelated to the point I was contradicting.So i think it's safe to say that this won't be a FALD HDR display
My personal opinion (shared by Daniel from LG) is that we won't see any meaningful HDR from the 38GL950G.
