[..] @ Angilion will be happy though Pip Boy lights have been boosted according to the patch notes! (you can also buy PA Brightlight Helmet mods ingame which are like the sun
I found a mod to fix the problem weeks ago. If I hadn't then I would have stopped playing. Power armour lights were
that badly broken. Which is why Bethesda finally got around to fixing the problem. It would have been nice for them to offer a choice so that players who actually like walking around with most of the screen black and seeing only a small, short, dimly lit cone of the world could continue to do so.
They won't ever do that the entire game is built around you playing for months & months & hopefully one day will see something cosmetic in the Atom shop to buy using real money
as soon as they reduce the need to grind everything the game would die overnight there are already way too many players still active who used the duplication glitch to get extreme amounts of everything!
The person you were replying to said nothing about anything to do with grinding and nothing to do with anything cosmetic:
Hope they release a patch soon to bring the weapon plans to any level character st the trade spots.
The issue they were referring to is that vendors who sell weapon plans will only
ever do so to players in specific level ranges. That has nothing to do with grinding. I could grind for a billion years and never get the plans to build a home made gun because they're only sold to players under L45. This is not a cosmetic thing. It would make no difference if a paint job for the home made gun was put in the atom store. It's a practical thing (within the context of the gameworld). I will never be able to make a home made gun. I could server hop a billion times to change the Free State vendorbot's inventory. I could spend a billion pounds on atom points and buy a hundred million skins for things. It wouldn't make any difference at all because the problem is that there are level limits on plans sold. Not just lower level limits but also upper level limits. So a player above L45 can never, ever buy the plan for a home made rifle from the single vendorbot that sells it.
This is a pointlessly annoying game mechanic made far more annoying by the fact that Bethesda didn't even bother informing players of it. There is no way of telling that this downright bizarre restriction is in place. None whatsoever. It particularly punishes players who explore because they're the people who are most like to exceed the maximum plan buying level before reaching the relevant vendorbot. It also very strongly encourages server hopping because if you do reach a vendor that sells a plan you want and you're in the level range you
must server hop right away as a top priority until you get that plan or else you will never get it.
I've no doubt that there are unstated and unknown level limits on other plans too.
Deliberately making utterly pointless restrictions on basic things and deliberately not telling players about them is not a good thing to be doing, but FO76 proves that Bethesda is (for some unknown reason) currently committed to being rude and annoying to its customers.
