Which is totally unimpressive....to a pair of DT 770 Pro closed-back (250 ohms). the SMSL DAC powers these well with the volume level turned up to 1pm which gives great sound and volume levels, the 4 on-board amplifier was too quiet to power these headphones. You would be able to power 80 ohm headphones with the on-board audio amplifier easily enough, the MSI B350 with ALC 1220 is NOT capable of powering high ohm headphones from my experience, yes they will work but the volume is not high enough to get what you need from a decent set of quality high ohm headphones.
DT770 should have pretty equal power need per dB as DT990 (same driver in both) and standard Realtek drives them easily past hearing safe volume.
I've tried with Sandy Bridge era basic motherboard using low end ALC892 chip.
About 35% volume setting started going past comfortable.
Which isn't really wonder, considering 250 ohm Beyers should have ~0,3Vrms signal need for 90dB and Realtek chips are specified for 1-1,1 Vrms output into current hogging 32 ohms and likely rising to 1,5+ V with low current loads.
While there's no available datasheet for ALC1220, it just wouldn't make any sense for Realtek to make it worser than lower end chips.
Motherboard makers are just more interested in maximizing amount of marketing hype, so actual implementations are likely half the time total screw ups.
And with real headphone amplifier volume knob is still well below 12 and also Windows volume setting (not amplification, but decrease of signal from full scale) below 30%.
With Windows (and other software) volume at 100% and full output scale in use, I would likely have to keep volume at 8-9.
When using low gain!
At high gain there likely wouldn't be any usable volume adjustment range without dropping volume from Windows to below 10%.
For another perspective Sound BlasterX AE-5 can push out more power than that 200mW K700-serie AKGs are specified to tolerate. (meaning possible damage to headphones)
250 ohm Beyers resist current enough that AE-5 runs out of output voltage before their specified max power is met.
Again it could push over twice the Beyer's rated max power into 80 ohm DT770.
