I don't think there's much point since the card uses such little power when idle anyway. Must less than my RX 480 did.Anyone found some good underclock(s) with the new software? Seeing as it now allows you to change State 1 - 7.
my bad.Anyone found some good underclock(s) with the new software? Seeing as it now allows you to change State 1 - 7.
Same thing applies. If it already uses 2-3 W in idle mode you're not gonna improve that much by tweaking the P1-P5 voltages.I meant undervolt, oopsmy bad.
So im doing a full new build next month and have seen the sapphire Vega 56 pulse for £315 on ocuk. Does anyone think it'll go cheaper in the next month or two? Im thinking if anything it might go back up to £350+ and stay there with the 2060 only having 6gb vram people might just opt for the 56 with free games for cheaper instead.
My budget for a gpu is £400 but the 64 doesnt seem like its worth £100 over the 56, 2070 seems pointless at £500 and similar performance to V64, so im not sure if I should just quickly get the 56 now before they go back up to £350+.
Currently using a gtx 980 at 1080p, going 1440p which is the main reason for the gpu upgrade. gtx 980 will go to my brother who still has an ancient 10 year old gtx 260.
I think my card has a problem, I started getting crashes on Friday, tried a clean install of drivers using ddu, nothing is over clocked everything is at stock. All the games I try crash after a few mins. BF1,ROTTR,FARCRY 5, I even ran the heaven benchmark and that crashed as well. Any of you guys have any ideas?
18.12.2
