Permabanned
- 29 Sep 2011
- melee island
Aye, but if it cant reach high clock speed then there are plenty of games that it won't be as good with as intel.
That's right. IF. And if it does?
Thing is though... AMD have not had the best single threaded speeds for yonks, well over a decade almost two?
Don't get me wrong... it would be great 'if' it were to happen... but I just dont see it.
As mentioned earlier cinebench is not a game.
True but not a huge of a gap. Where AMD falls behind is Clocks.
Clocks speed directly affects thread speed, and with regards to the link... the intel cpu can be clocked far higher than the amd cpu... so that gap just gets bigger.
Zen2 might get to 4.5Ghz with a slightly higher boost. Making the gap a bit smaller but with intel still winning, then intel will drop the cpus they have waiting and increase the gap again.Exactly what I said. Intels advantage is its Clocks. Against Zen+. Against Zen2?
I'll take a future forcasting guess then & suggest the core speed will not beat intel. Meaning they will only equal intel with some heavily multi cored games and even then not be quite as good.
We already know its at least as fast as the 9900K with the same number of threads.
i9 9900K 16 threads = 2040
R5 3600 16 threads = 2057
And those scores are not finalised clock speeds, in fact because of its system power consumption 180 Watts 95 TDP 9900K vs 130 watts this Ryzen sample; its believed it isn't even the higher clocked 3600X but the 65 watt 3600.
Intel are in deep poo, wait is my advice.
Its the dawn of a new age... pc's are finally going to get to crazy levels of performance (from what we've had ALL this time cause of stinktel)
Pinch of salt rumours but in the press briefing before the CES Keynote AMD's representatives were said to have boasted that their lowest end Ryzen 3000 would have the same number of threads as Intel best from 3 months ago (That would be the 8700K) and beat it in performance.
Are you honestly trying to tell me that a gamer using an Intel CPU would be just as likely to encounter bugs in new games and new technology than a gamer using an AMD CPU?
Clearly Intel has the most bugs;
AMD bugs
Meltdown-BR
Spectre-PHT (Bounds Check Bypass)
Spectre-BTB (Branch Target Injection)
Intel bugs
Meltdown-US
Meltdown-P (Foreshadow)
Meltdown-GP (Variant 3a)
Meltdown-NM (Lazy FP)
Meltdown-RW (Variant 1.2)
Meltdown-PK
Meltdown-BR
If you're claiming that AMD has more bugs in games, then that would be down to the game developers for writing sloppy code. Either way, it sounds like you're plucking claims out of the air, in a last-ditch attempt to make AMD look bad.
Didn't intel mitigate those except Foreshadow and Portsmash? But, still, if you have clients data in your network, then it's just ethical to protect them as much you can.
I should hope so. I was just defending AMD from trentlad who thinks AMD make inferior products with more bugs.
