Hey all,
Recently i started up my computer as normal but noticed my audio was crackling and breaking up.
I performed these steps to no avail:
- Changing audio leads
- Trying headphones
- Restarting Windows
The problem remained however so I booked for my soundcard to be RMA'd as it's only a few months old (it's a SoundblasterX AE-5). While waiting I put in my old card, a Soundblaster Z that's about a year old. To my surprise the issue remained.
I then tried/checked the following:
- Reinstalled Windows 10 fresh
- Tried on-board audio, this worked absolutely fine
- Moved the soundcard to the other PCI-e slot
- Tried my speakers from the front audio out which is connected to the soundcard, this worked fine
I'm really confused. On-board audio is fine but 2 different soundcards in two different slots have crackling audio on the Speaker Out, but work fine with the cable to the front Speaker Out.
Sometimes when plugging in the Speaker cable, Windows will freeze/lock which it never used to do but again, I have reinstalled Windows
I'm really at a loss as to what the issue is. I think maybe the motherboard but the chances of two slots being bad seems unlikely?
My PC specs:
Gigabyte Gaming MX-5 micro ATX motherboard
Soundblaster AE-5 / SB Z
Asus ROG Geforce 1080
Windows 10 Pro 64-Bit
16GB Corsair DDR4 RAM
Thank you all in advance
- Trying headphones
My PC specs:
