Just buy an ASR1000 imo![]()
Looks goodMy R210 II has proven to be fantastic so far, I really like it.
How are you finding it? Noisy? Quiet? What are you running on yours?
Put ESXi on as a base and then try VyOS
I can't fault it one bit. It's neither noisy or quiet, really. It sits under the stairs with all my AV equipment, so it's always warm under there, but I can't her it with the door closed and temps are fine.
I'm running Server 2016 with pfSense and W10 in Hyper-V. It runs really nicely. pfSense is loaded up with pfblockerng, snort and squid proxy and it barely even flinches under load.
I forgot to ask, how much did you pay for the idrac and where from?
£15 from China. To be honest I'm amazed it arrived and worked so £15 very well spent. All the UK ones were £50+
Probably should have stumbled across this earlier on the forums rather than via google, I picked up a 210ii last week and the iDRAC/1270v1 just arrived so I can go back from VM to bare metal. I still have ear defenders from my GPU mining days, i'll dust them off![]()
 I've got the idrac too now, still running hyper-v. I might go bare metal though as my other server handles everything else now.Make sure you do all the updates (there's a handy iso from dell) it should be whisper quiet. Mine never makes a noiseI've got the idrac too now, still running hyper-v. I might go bare metal though as my other server handles everything else now.
I noticed the later BMC/BIOS updates are reported to make a noticeable difference, at worst I have resistors, a soldering iron and the scars from previous fights with Delta screamers... I fear no fan. The 1270 is massive overkill, if it gets above idle I expect fan noise, but the cost difference between a 1220v1 and a 1270v1 was £12 and that buy's a lot of resistors/solder.
Since I left this thread I've now moved back to the R210ii and upgraded the CPU to a 1270 (I think) 4c/8t and done a lot of CHR research. It running it without HT apparently does wonders and last speedtest I managed to do 10+Gb traffic to itself.
Out of curiosity @Steveocee did the use of a non Dell validated NIC cause the fans to spin up at a higher level? I ask as it's common for non validated PCIe devices to cause the fans to run at 100% on HP hardware and they can be very petty about devices being certified for specific generations.
Did you disable HT and gain performance?
