- 22 Nov 2018
7nm Zen 2 is late, look at what TSMC is doing with its 7nm capacity, already.
AMD's normal Ryzen release is April. So the 3000 is only going to be 2 months late.
https://www.reddit.com/r/Amd/comments/ahxxpg/der_8auer_thinks_5_ghz_on_ryzen_3000_is_very/In his Q&A (ger) live stream 1:04:50 der8auer told that he thinks 5 ghz on ryzen 3000 is very very realistic. He claims that he got industry sources.
IIRC a 2700X can reach 5.5-6Ghz on LN2 so 5Ghz for R3 seems like an almost dead cert, i guess he could be talking about an OC on less exotic cooling but seeing as he's an 'extreme' overclocker that seems unlikely.
I keep changing my mind but I'm expecting 4.7-8 maybe 4.9 from the fastest choices at best, For me the big question is will we still have the same situation where there's no silicon lottery to speak of?
So far we can all pretty much get the same clocks with the right cooling which is good if you're not into overclocking like me but also a bit sad.![]()
If they can bin chips that can reach 5 GHz, they will. Their marketing people will understand the allure of the "magic 5 GHz mark", even though in reality it means nothing.
Many things are defined by marketing. They used to have more power than currently as specs have become more important again, but from Intel's marketing perspective they'll be screeching for more cores and the engineer's are likely scratching their heads saying, not possible with current monolithic tech...Does the market department really have that much influence over the final clock speeds?
With all the sensors on chip to verify operation these chips will be expertly binned, overclocking will only be for those willing to pump massive volts and extreme cooling etc, there will be next to nowt for free from a modern chip, previous two gens were the same.
If Ryzen 2000 can reach 5.5 - 6GHz using LN2, why would Ryzen 3000 be limited to only 5GHz using LN2? Surely he means 5GHz on air?
That's not to say I expect 5GHz on air myself, but that's what I think he's expecting.
Zen hasn't been any super low power design any time.There are reasons why a reduction in node size would reduce clockspeeds but from what i understand they don't really apply to R3 or TSMC's first foray into 7nm because AFAIK they're kicking of with a performance orientated design instead of a low power one like the did with 14nm.
The two previous gens were not on exactly stellar processes though, and it was at its limits in order to try and compete at the high end of the market. Depending on how good the 7nm process is and how good the yield is on each wafer, you could end up in a position where they need to bin down some of the silcon to fulfil demand at the low end of the market, making a part that can be overclocked not unlikely. Alas, as with everything we have both said, it is merely speculative and won;t be known until we have final silicon in end user hands.
At the moment I'm not even going to really try it, because the first game I wanted to try (God Of War 3)'s not really playable on my 2700 with it. Guess I'll have to play it on the PS3.
Sony has already done it for you
https://www.playstation.com/en-gb/games/god-of-war-iii-remastered-ps4/ on a setup much cheaper than an upgrade, it just works out the box.![]()
Good die will be TR/Epyc bound, the beauty of this single design throughout entire product family is you can use the best for the place that gets the best margins and sell the rest to the plebs.![]()
