Here's mine...Anyone here using the phanteks vertical riser have the same issue as me in not seemingly getting a flush mount (see pic)?
https://ibb.co/qdTfK9q
https://drive.google.com/file/d/1zjEbGoz_XfYzVKCuWheXyyrrCjPwruxt/view?usp=sharing
Yeah, running fineThanks mate. Looks like your retaining arms didn’t pop up but guess you’re running with no problems?
So for dual motherboards do you have to go for Revolt X PSU or is there an alternative solution?
@Cooper If your talking about the P600S, i just tried and managed to get it off around 40-45 degrees with a bit of effort.. the only trouble is if you did this often i think you would damage the rubber seal that is on the inside of the glass as it catches at those angles
my case is about the same distance from my monitor too but i find it easy enough to unplug the monitor and move it if i need the extra room... depends on your setup though
It is probably the cables of the ssds bending that are doing it. From what i have seen of reviews it is a common complaint, though i'm not quite there myself yet.Just build my evolv x and installed my SSDs on the bottom side flat...however my case door seems to struggle closing - I can't seem to see anything causing this. I'm worried the scews (screw heads) holding the SSDs in place will cause an issue with the side panel :/
Very late I know, but did you get rid of these?Before I throw them out, anyone want my hard drive mounts? I won’t be using them.
Just pay postage/pick them up
If you are wanting to get rid of them I'll gladly pay the postage to take them off your hands?I have three cages and the bit of plastic that goes on one of the top holes.
Don’t force it as I have had 3 ssd broken due to this in the bottom trayJust build my evolv x and installed my SSDs on the bottom side flat...however my case door seems to struggle closing - I can't seem to see anything causing this. I'm worried the scews (screw heads) holding the SSDs in place will cause an issue with the side panel :/
