- 20 Nov 2014
Excellent man maths.
So do it already![]()
Engine build or wide body first
Not quite that simple on direct injection cars, the fuel systems operate in the 150-200bar region Vs 3-4 bar for port injection.A 5 cylinder engine? Or just upgrade half of the injectors on a V10?
That's some quality looking pipes there!
There's a TT online with something stupid like 1000hp
Featured on the llf channel
Overall the V10 most likely also has a fuel system capable of less outright lower than the TTRS too as it produces less power per cylinder and naturally aspirated engines require less fuel to produce the same power
Its dead easy just add 5 more injectors![]()
