Caporegime
- 18 Sep 2009
- Dormanstown.
Just wait until tomorrow.
Indeed. Something that beats the 2080 and trades blows with the 2080Ti would be a good sell.Just wait until tomorrow.
Sounds credible, if it had the ability to pull shader performance from another dimension![]()
The GTAV result is questionable considering how far AMD gpu's lag behind Nvidias.
EDIT: Huh! The GTAV result is nothing like that if you check via the link.
EDIT 2: I'm such a numbnut sometimes, Was looking at 800x600.
EDIT 3: No I wasn't, Just sell me one already![]()
I would really really hope no one is buying these cards for 1080p.
Why not?I would really really hope no one is buying these cards for 1080p.
Same here, unless it's more than double the price of Vega 64. That doesn't make any sense for only 25-30% more perf. I would rather buy two vega 64, but crossfire is so useless these days...I'm definitely doing the F5 dance if that's the case, but my gut tells me it will more likely trade tit-for-tat blows with 2080 (and 1080 ti). Even so, it's still a reasonable option for someone looking for that level of performance (unless the retail price is sky high)
OK cannot do voucher codes!
We shall just price competively and well you need to be quick guys, I shall aim to put live at 13:50, so you get a ten minutes heads up.
Also to speed process use only debit/credit card, using Amazon or Paypal takes longer to come through on our system and if there is a mad rush, you will miss out.
I've got no chance as I will be at work.OK cannot do voucher codes!
I'm going to imagine it's another 2080 performance product for 2080 price. That's the AMD way these days.
AMD have got a product that people want but not enough numbers to supply them.
A bit of **** launch to be truthful.
Oh well, most probably just stick with what I've got for longer.
